C15 Accert losing prime on suction side
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by bradyb22, May 13, 2023.
  1. bradyb22
    bradyb22 Bobtail Member
    I’ve got a 2006 C15 Acert that is getting air in the system on the suction side before the fuel pump. The pressure side of the fuel system will hold pressure fine. It started out the truck would lose prime overnight now it is only taking an hour for it to happen. The truck always fires up fine but starts to miss and die after 30 seconds or so. If I fill the primary filter before each start it run fine and doesn’t miss but if not it eventually will die. Everything I’ve read makes me think it’s sucking air somewhere possibly a bad line but with it losing prime so fast now I would think I would be able to see a wet spot somewhere that it’s letting air in. Any insight is greatly appreciated.
  3. North Pole Nightmare
    North Pole Nightmare Heavy Load Member
    855
    1,666
    Dec 15, 2021
    There's a check valve that's probably bad
  4. bradyb22
    But where is there a check valve on the suction side of the fuel system? I can’t find anything from the tanks up to the transfer pump? Nothing where the fuel lines T together behind the cab and nothing on the primary filter housing.
  5. Big Road Skateboard
    6,190
    34,006
    May 2, 2021
    You're not going to see a leak if you're sucking air.
    I normally verify by putting a line from the filter and drop it right in the tank. Get it primed and run it a few minutes, then shut off for an hour and see what happens.
    You'll know pretty quick
    bradyb22 Thanks this.
  6. JB7
    JB7 Heavy Load Member
    791
    1,218
    Dec 13, 2022
    Laurel, MD
    3406E Losing Prime | Page 2 | TruckersReport.com Trucking Forum | #1 CDL Truck Driver Message Board (thetruckersreport.com)
    Go to message 20 and the attachment. Page 1 see #10 transfer pump and #12 check valve. Probably best to replace the transfer pump. There is a thumbs up in blue below what someone types if you like the response.
    bradyb22 and Oxbow Thank this.
