C15 Acert backfire when cold
Discussion in 'Trucks [ Eighteen Wheelers ]' started by KDubFarmer, Dec 27, 2015.
  1. KDubFarmer
    KDubFarmer Bobtail Member
    14
    Have been having problems for about a year or so now with my C15 Acert backfiring when cold until it gets to full operating temp after running down the road for a bit. Traced it down to a bad injector, which was replaced, and also had the valve lash reset/adjusted.
    Got it out of shop and still does the same thing, although not near as bad. Its most noticeable in the winter right away in the morning until like I said you get it up to full operating temperature after moving down the road.
    I always start it up in the morning, let it build oil pressure and set a fast idle and let it warm up that way for 20-30 minutes before taking off. At that point engine temp is usually around 120-130, sometimes maybe as high as 150. Its ok when you first take off until you get into high range and really start to pull the motor with each gear change. At about 1300-1500 rpm you get a jerking/bucking. Will do this until motor gets to 180-200 in temp.
    And the colder it is outside the worse the problem is despite engine temp. At 130 degrees engine temp its worse when its 15 degrees outside vs 30-35 degrees, which is worse than when its 50 degrees out and so on. But once the engine is warmed up for the day it runs just fine. And it will give this problem loaded or empty but probably more noticeable when loaded.
    Is it still an injector problem? Something else in the motor/drive train?
  3. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,730
    Jan 30, 2010
    keep stroking.
    I will bet it is an valve actuator sticking. a bad injector will not make it back fire. a vva will make it sound like it is back firing.
    SAR Thanks this.
  4. DL550CAT
    DL550CAT Road Train Member
    1,427
    1,482
    Oct 18, 2009
    Waynesburg, Pa
    Head gasket. It's probably blown between cylinders. I ran mine that way for years. When I had it I framed I had to have the spacer plate replaced it was eroded so bad. I was told it the only sign was a cold miss.
  5. jammer910Z
    jammer910Z Road Train Member
    2,446
    6,522
    May 28, 2015
    Fouled spark plugs....:D
  6. Smellfunny
    Smellfunny Road Train Member
    1,445
    967
    Jan 28, 2012
    South Carolina
    I would agree about the VVA. Do you have any engine codes? I had one doing that the other day and it turned out that the jam nut for the #5 intake valve was gone. The adjuster backed off. He was getting a code for #5 VVA at times.
  7. KDubFarmer
    14
    Well I guess I'll describe it as a backfire, that's what it acts like and when I had a mechanic ride with me he put it that way. But let's just say there's a jerking and bucking like the engine is cutting out when its doing it. A bad injector was found and also someone had "attempted" to work on/replace all the others at some point...found out they were all out of order and set to the wrong cylinders. Fixed that problem as well. But like I said all the injector work did help, its not doing it as bad now.
    And if its head gasket related would I possibly see it leaking somewhere or start to see some coolant showing up in the oil? I'm seeing none of that
    How much of a job I'd a VVA? Honestly I'm surprised the mechanic didn't check for that anyway, he's quite picky at checking EVERYTHING. But I don't think there's any codes coming up so maybe he did and just saw nothing. but I can run this idea by him.
    Honestly I'm about to sell this truck. I bought it a year and half ago and all I've done is beat my head against the wall ever since. Whoever had this thing before me wasn't big on maintenance and plain just ruined some things due to lack of and let some things just keep going that should've been replaced long before I bought it. Not sure if they were doing the work themselves or had a mechanic but whoever was doing work on it should be shot. Of course the place I bought it from did a good job at hiding and covering a lot of stuff up.
  8. Superhauler
    12,209
    100,730
    Jan 30, 2010
    keep stroking.
    there is a test you can run on cat et. does it reveal the problem? sometimes it will and sometimes it wont. do the test before you throw more $$$ at it. run it up the road while you do the test with mech sittin in the passenger seat. head gasket very doubtful with the symptom your describing. to replace the vva housings isn't cheap but maybe what has to be done. check and see if the oil bridges to the vvas are not leaking or cracked they get overlooked a lot.
    SAR Thanks this.
  9. skateboardman
    skateboardman Road Train Member
    6,232
    5,706
    Jan 14, 2012
    flatbed heaven
    I had same problem, exactly the same, it was like it was cutting out at 13 to 1500. Onlyvwhen cold , it dropped a valve on #2 cylinder, after platinum overhaul. Wit 3 new vva. Housings and new turbo's. It doesnt. Do it anymore. But I think it was. Vva housings cause in g the problem one broke when taking the engine apart, the. Housings are 845 each. But its injector or vva
  10. W903B
    W903B Light Load Member
    80
    26
    Jun 5, 2016
    That is cat cold mode in ECM settings , emissions related to prevent white smoke. Nothing is wrong with engine .
    SAR Thanks this.
  11. W903B
    80
    26
    Jun 5, 2016
    I hope you figured it out by now that it is cats cold mode as ECM settings to prevent white smoke just be above 1400rpm and build temp 165°
    Don't throw parts on it , all is good and change to more problem solver mechanic
    SAR Thanks this.
