C15 Acert BXS shuts off-throws no codes HELP!!!!
Discussion in 'Trucks [ Eighteen Wheelers ]' started by shamrockman, Sep 17, 2013.
  1. shamrockman
    shamrockman Bobtail Member
    10
    2 months ago I bought a one owner 2005 Pete 379 with only 505,000 original miles. The truck is show room new in condition inside and out. The manufacture date is 2004 and it has a BXS acert 475 Cat in it. I bought the truck for 25k less than the market knowing that it had a shutting off problem. I thought we could figure it out in no time at all, but here I am 2 months later writing this thread. The truck runs great with no misses at all for days at a time, and then all of a sudden while cruising down the road it will die. The truck will start right back up without any hesitation. It may do it again in 30 minutes or it may be 10 days later before it acts up again. When it dies, it does not set any codes. The part changers at Rush Peterbilt looked at the truck 4 times before I purchased it without finding the problem. Since I bought the truck, Holt Cat has looked at it along with 10 different shops, each of which were confident they knew what was wrong. We have replaced the ignition switch,checked the wires going to the ECM from the battery, changed the batteries around, replaced the acc relay, replaced the shut off timer, checked the oil pres sensor, and unhooked and rehooked every single wire on the truck. One more clue for you, the speedometer just started acting up about 10 days ago, jumping up and down 5mph or so. We put a new speedometer on and cleaned all the connections and it is still bouncing around. Should we try replacing the ECM??? Has anyone had this problem and did replacing the ECM fix it? Thanks so much for any input.
  3. peterbiltswag
    peterbiltswag Bobtail Member
    24
    6
    Mar 7, 2013
    on a 379 peterbilt there is a two wire conector for constant ecm power supply from battery box to ecm, seen many problems with weatherpack connection, should be located at top of frame rail on left side above starter area, start truck and move connections and see if truck dies, if so, cut connection out and hard wire around, good luck.
  4. Garbologist
    Garbologist Bobtail Member
    10
    Sep 9, 2013
    Just had the same probelm the ecm ground wire was broke at the battery terminal it was a one piece terminal check the speed senor my be good bad
  5. manasteel
    manasteel Light Load Member
    124
    32
    Sep 10, 2012
    try running a wire to ecm pin 70, this is key power to the batteries with an alligator clip. run this for a few days see what happens if it helps you will at least have a direction. you need battery power to pins 52 and 53 battery ground to pins 65 and 67. I seriously doubt the ecm is bad. you might remove the fuse box flip it around and see if the wires at the lower ign breaker are not rusting off
  6. ISXunlike
    ISXunlike Bobtail Member
    47
    34
    May 12, 2013
    Cortez, CO
    I had an 05 bxs acert that had similar problems for a couple of months, then one day it died and never started again. At that point it did throw a code for something injector related, but I put a new ECM on and never had another problem. If you are confident your wiring is good that would be my guess, unfortunately it's pretty expensive to do a trial part changing with, but if you could find someone with a spare ECM to try for a bit to see what happens? Good luck!
  7. shamrockman
    10
    Thanks so much, I will try that tomarrow. I'll let you know.
  8. shamrockman
    10
    That's pretty much where we're at on going ahead and replacing the ecm. We have 5 more acerts with mxs motors that the ecm is different on. May just have to bite the bullet and buy a new one.
  9. ISXunlike
    47
    34
    May 12, 2013
    Cortez, CO
    You might try getting in touch with a Mr. Haney on this forum to get a pre-tuned ECM. He gets high ratings, and if you're going to spend some money anyway, may as well upgrade the horsepower while you're at it. Just an idea, don't know what you're into.
    shamrockman Thanks this.
  10. morehp
    morehp Medium Load Member
    699
    206
    Jun 18, 2012
    Something else for you to check, there should be a 5A fuse in the fuse box ( top row from memory ) that supplies power to the ECM, check the terminals are not corroded on that and its nice and snug. Also do the dash lights or anything else die when it does it ? I have seen problems like this before when i had a big footed driver kicking the fuse panels as he's dancing on the pedals.
  11. Mr. Haney
    Mr. Haney Road Train Member
    2,693
    2,041
    Dec 17, 2008
    The speedometer issue is the speed sensor in the tailshaft of the transmission. Eaton changed them to a cheap plastic housing that glues together. The glue breaks down at the seam where the top of the sensor housing is mated to the lower portion and allows moisture to enter the sensor. Corrosion builds internally in the sensor and degrades the sensor signal to the ECM and gauge. The first sign of this problem is erratic movements of the speedometer needle of the gauge.
    The shutting off issue is one of a few things. The power supply from the batteries this usually stores a fault code in the ECM. The power supply from the ignition switch, this usually will not leave a fault code. The injector drivers in the ECM are failing. This is a common problem with the particular ECM you have, but this will also store a fault code. You could also have a cracked circuit board in the ECM that isn't allowing keyed power to be registered by the ECM at times. This would shut the truck down in the same fashion as turning the key to the off position. It wouldn't register a fault code, but at the same time you will not be able to communicate to the ECM with Cat ET either. Over the years I've run into a very few ECM with cracked or broken circuit boards in them. Usually when I do find one that is bad a function of the ECM doesn't work. Such as the jake will only work on two stages or the manual fan switch will not work, because the input signal isn't making it to the circuit board. I've never seen one do what you are describing.
