C15 Acert MXS overhaul
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by TankerYanker505, May 7, 2022.
  1. TankerYanker505
    TankerYanker505 Bobtail Member
    I know there’s may different opinions but I’m looking for some knowledgeable advise. Rebuilding a MXS and have decided I’m going to do the 16:1 low compression kit and 800hp cam. From there is it better to leave the twins, tune it and delete the ivas or do the full 6nz conversion. Injectors, ecm, single turbo, manifold. Wanting to run around 650-700 hp
  3. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    What year is your truck, what rad. are you going to use?
  4. idriveaholden
    idriveaholden Super Heavy Hauler
    701
    2,202
    Mar 14, 2018
    Leave the twins
    Shawn2130 Thanks this.
  5. A5¢
    A5¢ Medium Load Member
    389
    544
    Oct 30, 2017
    I know absolutely nothing about doing a conversion. What I do know, is that there are a bunch of folks that do them and then have issues. What I see causing problems, is that not everything is getting done to the conversion to make it correct. In other words, just trying to hop up an engine and not throwing all of the time and money into the job. I am sure there are many conversions that went well, but there are certain mechanics that are going to read this and recall the ones that didn't go well.
    idriveaholden and Shawn2130 Thank this.
  6. Shawn2130
    Shawn2130 Heavy Load Member
    894
    1,892
    Sep 20, 2015
    Ontario
    I have factory twin turbos for the BXS. Works really well. No smoke, good low end power, and good response.
    spsauerland and A5¢ Thank this.
  7. idriveaholden
    701
    2,202
    Mar 14, 2018
    This is exactly what’s going to happen if you single turbo it..
    Oxbow and A5¢ Thank this.
  8. Short Pull
    Short Pull Light Load Member
    58
    86
    Sep 8, 2021
    If you’re gonna single it out, do it right. Don’t go cheap! This means getting rid of the IVA’s, putting a 6NZ harness on it and changing all of the sensors and ECM too. If you put a 201-2677 cam in it and a 78mm turbo you’ll have an excellent running Cat. Find someone knowledgeable to tune the ECM and drive the truck decent and you’ll have power to spare compared to an ACERT and mileage too.
  9. kranky1
    kranky1 Road Train Member
    2,253
    8,854
    Sep 16, 2015
    Ontario, Canada
    That’s a BXS. Twins are on it and the vva’s work. It runs pretty good.
  10. Shawn2130
    894
    1,892
    Sep 20, 2015
    Ontario
    I can’t fix the error. Too late I think. But thank you
  11. Shawn2130
    894
    1,892
    Sep 20, 2015
    Ontario
    Thats a lot of boost
    mine is 60
    Flint1 Thanks this.
