C15 Acert oil in water
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Diesel Dan 92, Aug 5, 2017.
  1. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,730
    Jan 30, 2010
    keep stroking.
    Yep, I still see some oil spots every now and then floating on top over a year when mine failed.
    Oxbow, Heavyd and Diesel Dan 92 Thank this.
  3. Diesel Dan 92
    Diesel Dan 92 Light Load Member
    137
    50
    Nov 27, 2015
    Thanks so much guys. I'm going to order an oil cooler, heater lines, and rad lines.
    Oxbow Thanks this.
  4. Diesel Dan 92
    137
    50
    Nov 27, 2015
    Well my local KW wants $930 just for the cooler..
  5. terryt
    terryt Heavy Load Member
    736
    777
    Apr 27, 2009
    make sure you do this at least three times or till clean or you will have problems down the road
    Oxbow and Diesel Dan 92 Thank this.
  6. Diesel Dan 92
    137
    50
    Nov 27, 2015
    image.jpg Well now I'm not sure what's going on guys.
    Ran about 150 miles today, half loaded at 150+ half empty at 45.
    Truck ran great.
    Pulled a sample after it cooled off a bit, I'm not sure what's in my coolant. Smells kind of like PB Blaster.
    Not as dirty as I initially thought.
    I may flush the system and refill, see if I get more contamination.
    I've only had this truck in service for a couple months and I haven't done a coolant change yet.
  7. terryt
    736
    777
    Apr 27, 2009
    oil will not look like oil it is gray and will be like butter or pudding the thing is it will over heat real quick with out warning and have seen to many play around with an oil cooler using stop leaks only to blow a head gasket or crack a head just staying don't bury your head in the sand. pay me today or pay me A LOT later.
    Diesel Dan 92 Thanks this.
  8. Superhauler
    12,209
    100,730
    Jan 30, 2010
    keep stroking.
    If it is fuel in the coolant. It will be injector cup o-rings. But you need to figure it out SOON!
    snowman_w900 and Diesel Dan 92 Thank this.
  9. Diesel Dan 92
    137
    50
    Nov 27, 2015
    I'm leaning fuel at this point. Going to flush it this week and run it a bit to determine wth is going on.
  10. Cardy
    Cardy Bobtail Member
    7
    Oct 21, 2017
    Coolant will settle in the oil after you turn your unit off, think hot coolant 14psi for 3 hours after you 0 your engine and transmission oil pressure. You should see coolant if it's leaking there. C15s have horrible cgi coolers though that trap the coolant. Get a 80$ gas in coolant tester for diesel, cats don't always work could do a bouble test off the rad.
  11. Diesel Dan 92
    137
    50
    Nov 27, 2015
    So I flushed the rad and put in new coolant. Ran for a few weeks no problems then one day puking out the overflow.
    Diesel.
    Replaced injector cups and o rings.
    Flushed, filled. Hopefully good to get now.
    Oxbow and SAR Thank this.
