c15 acert pushing coolant out radiator
Discussion in 'Trucks [ Eighteen Wheelers ]' started by dieseldan2005, Sep 15, 2013.
  1. dieseldan2005
    dieseldan2005 Light Load Member
    185
    17
    Feb 6, 2009
    North Branch, MN
    I have yet another problem with my 2007 t600. It started pushing coolant out of the overflow tube yesterday. Its never done this before. I have no other issues with how it runs, no overheating, rough running, etc.. I added some to it about 2 weeks ago and i might have overfilled it, but i have added it before and its never pushed it out. I drove the truck for about 5 miles home yesterday and went to take the pressure cap off and it blew coolant out so i closed it quick. About an hour later it still had a lot of pressure in it. Its never had that kind of pressure before. I could take off the cap when i would be done for the day with barely a poof of pressure. I have no bubbles in the tank except for some very minor ones about every 30 seconds which seems normal. Before everyone condemns my head gasket is there anything else that would cause this? Air compressor, bad cap, etc...? Truck has 767k miles on it. Also what about the water diverter valve that i have read about? Any help would be greatly appreciated!
    superhauler Thanks this.
  3. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,728
    Jan 30, 2010
    keep stroking.
    air compressor, over filled radiator, or what I seriously think it is headgasket! sorry!
  4. Superhauler
    12,209
    100,728
    Jan 30, 2010
    keep stroking.
    you mentioned water diverter valve, no but it might be the precooler leaking. easy to check, just take off the pipe that runs from the precooler to the cac and look down in it with a light. if you see some crusty deposits on the tubes that could be your problem.
  5. dieseldan2005
    185
    17
    Feb 6, 2009
    North Branch, MN
    Ok, well i will see if cat can look at it tomorrow. Would that precooler cause an increase in pressure?
  6. Superhauler
    12,209
    100,728
    Jan 30, 2010
    keep stroking.
    im not sure. but under boost 30 to 50 lbs that's more than the rad cap holds so it could cause it. I have never heard of it but what I have seen in the past year anything is possible.
  7. dieseldan2005
    185
    17
    Feb 6, 2009
    North Branch, MN
    Ok, yeah i also have no water in oil or any other symptoms like that. I watched the water level rise up quick with the cap off and engine cold. It was under the filler neck then shot up to the middle of the neck quick like. Never went any higher with the cap off.
  8. Superhauler
    12,209
    100,728
    Jan 30, 2010
    keep stroking.
    check the easy stuff first. then have them do the (bubble test) in a bucket. I am leaning toward headgasket though. hate to burst your bubble! (no pun intended)
    Hardaway319 Thanks this.
  9. dieseldan2005
    185
    17
    Feb 6, 2009
    North Branch, MN
    No i know your not trying to. I just got started as an o/op and do NOT have the money for a head gasket or inframe now. This truck has been nickle and diming me to death so far. I didn't want to hang it up this quick. I like what i am doing. How much is the average rate for a head gasket?
  10. morehp
    morehp Medium Load Member
    699
    206
    Jun 18, 2012
    Take a good sniff and See if the coolant smells like diesel, hopefully for your sakes it is just injector sleeves.
  11. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    You can not test a unit with the Rad cap off, or defective, the water pump is a centrifical pump and without preasure to seal it, it will draw in air.
    To do a proper bottle test go to the Diesel Garage site and search Handy links, then down to the Bottle test, do the complete test. It will give you the information you need, I know I wrote it!
    Just a thought!
