C15 acert upgraded fuel transfer pump question
Discussion in 'Trucks [ Eighteen Wheelers ]' started by SimD, Mar 18, 2013.
  1. SimD
    SimD Light Load Member
    148
    30
    Dec 23, 2012
    dallas, tx
    Does the upgraded T-pump come with a upgraded spring?
  3. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,114
    May 19, 2011
    When I bought mine two years ago it did not.
  4. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    no you have to buy it separate>
    SimD Thanks this.
  5. bigstank
    bigstank Light Load Member
    87
    19
    Mar 4, 2013
    missouri
    Dumb question here. But what does the upgraded spring do on the pump and do I have one on my 02 6nz? Like I said I'm new to this cat power stuff and praise you guys who have the knowledge
  6. Superhauler
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    stronger stiffer spring. holds the bypass closed better! raising fuel pressure. check fuel pressure before anything. if below 90lbs. then you may have the weaker spring. if your trans pump has a allen head fitting on the side, then this spring will work. if it's the regular bolt head you have the old style pump with the narrower spring. that one you just shim the spring. but be careful you dont loose the pin and valve piston when you take the spring out. the allen head style just has the valve piston in it. but like i said check your fuel pressure first around 100lbs is the best. at high idle. (1700rpm)
    Bosnaian379, mitchlocke, SimD and 2 others Thank this.
  7. bigstank
    87
    19
    Mar 4, 2013
    missouri
    Ok thx ill check it out also ima send u a pm about a injector question
  8. mtoo
    mtoo Road Train Member
    1,928
    4,427
    Jan 15, 2011
    Retired on bended knee
    I put one on the first of the year,the pump has been updated to 384-8611, this pump comes with the 339-4983 spring installed. before install pressure at idle 75-76 @ 1900 89-90. after install idle 81-82 @ 1900 99-101. It was an easy driveway install. This was on a 6NZ
    bigstank and logtrucker25 Thank this.
  9. SimD
    148
    30
    Dec 23, 2012
    dallas, tx
    superhauler I'm thinking about just shimming it with a metal washer good idea or bad, If good idea what size should I use?
  10. Superhauler
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    cant remember size. but if you have the new style make sure the washer fits over the nub on the plug. you may have to drill the center of washer out to do this. but it's a temp fix the weak spring will get weaker after a while. better off getting the stiffer spring. if older pump brass washers that will fit in the end of plug resess.
    Ttimefr, bigstank and SimD Thank this.
  11. SimD
    148
    30
    Dec 23, 2012
    dallas, tx
    I have the older style pump, peterbilt wants freaking $230 for a new style
    bigstank Thanks this.
