C15 ecm wireing diagram
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Shawn19, Aug 1, 2019.
  1. Shawn19
    Shawn19 Light Load Member
    117
    34
    Apr 20, 2019
    I have 06 international 9400i with a c15 I been having problem one day I turn off the truck 30mins later turn key no power and I mean nothing no ignition power no lights no radio nothing check all fuses relay they are good I don't have a fuse in my battery box going to the ecm I checked power at the key ignition no power run a jumper power wire to the key ignition start right up been working good for about a month until my check/service light come on for 3sec I lost power and goes back off truck back to running normal I scan my truck and it say low battery power to ecm.
    Anyone has the wireing diagram to the ecm so I can run a power and ground wire directly.
  3. Muddydog79
    Muddydog79 Heavy Load Member
    820
    2,147
    Apr 14, 2016
    Go to the search tab and enter Cat wiring diagram. You will find what you need there.
    Oxbow Thanks this.
