C15 head cracked between intake valves
Discussion in 'Trucks [ Eighteen Wheelers ]' started by JustinofPeteNYC, Apr 4, 2013.
  1. JustinofPeteNYC
    JustinofPeteNYC Bobtail Member
    40
    Feb 26, 2013
    Pulled the engine cause it spun a rod bearing and wiped out the crank. Today I started to clean the head up and noticed all 6 were cracked between the intake valves. I'm hearing that its ok and I'm hearing it needs a new head. To me a cracked head is a bad head. Anyone have any experience with this?
  3. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,730
    Jan 30, 2010
    keep stroking.
    those cracks are normal in that area. but how deep they are is the question. I sent my head to cat for them to check it and resurfacing. cost about $500 to inspect. came back ok.
  4. king Q
    king Q Road Train Member
    2,880
    3,032
    Jul 26, 2010
    Johannesburg sa
    I'm not sure as I am not familiar with the C-15 head but have often seen it on heads.
    Some makes and models are more prone to it and if the cracks aren't to deep they seem to look worse then they are.
    I however could never get used to putting a head back when I knew it was cracked.
    I saw some manufactures (Mercedes) on some models machine a half moon type recess between the valves on later models of problem model types.
    I believe one of the leading causes is over torqued hold down nuts on injectors on some types of heads.
  5. Superhauler
    12,209
    100,730
    Jan 30, 2010
    keep stroking.
    if your going to reuse the head, I would still have it resurfaced instead of just cleaning it up.
    swaan Thanks this.
  6. JustinofPeteNYC
    40
    Feb 26, 2013
    I'm gonna pull the valves out tomorrow and see if I can see how far up the cracks go, on #2 is the biggest crack so that will be the first I'm gonna check. I know it's common for these heads to crack between valves but I just can't be comfortable with saying its ok for those cracks to be there.
  7. Gear head
    Gear head Medium Load Member
    532
    91
    Apr 1, 2012
    Belair,md
    My only fear is that the valve seat would come loose. But I have sent probably 75 cat heads back on with those cracks that cat says are ok and never had problems yet.
  8. straight pipe
    straight pipe Bobtail Member
    4
    Apr 4, 2013
    Montana
    If You Werent Burning Wate And No Fuel InYour OilThey Probably Are Just Surface Mine Had The Cracks An Was Okay But Was Warped So Had To Replace
  9. JustinofPeteNYC
    40
    Feb 26, 2013
    Truck got towed into shop cause it spun a rod bearing and seized the crank. Oil was already drained so not sure if there was any water in there or if it was burning oil. I guess the best thing to do is to send it out to get checked. Even if it comes back ok, how long till those small cracks spread??
  10. Gear head
    532
    91
    Apr 1, 2012
    Belair,md
    Ive got trucks that have put 500000 on the heads after I reinstalled. They were cracked and cat said they were fine and so far so good.
  11. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    Justin home many miles were on your engine? My 2ws spun a rod bearing also with a million miles on it. It seems like I'm hearing this more often in the last few years. My head was cracked in #6 and CAT said they would accept it as a core but there was a upcharge for the exchange head. I think it was going to be 2500 exchange.
