I have a 07 freightliner c15 check engine light came on truck run good so far even with a load drop load off and had it scan ( intake valve actuator #4 current low (93) )
Does anyone know for a fact if I can run it without fixing it or do i have to fix it ?
C15 Intake valve actuator # 4 current low (93) DO I HAVE TO FIX ?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Shawn19, Jan 8, 2020.
You can run with it, Your fuel mileage will suck and you turbo pressure won't go above 30lbs, but should be ok till you can get it fixed.
pushbroom and QUALITYTRUCK Thank this. -
check electrical
We have 3 C15's and a few times a year each of them throw a code for IVA. It usually goes away a day or 2 later. They run fine but like other posters have said you may get worse fuel mileage. I would run it. If the code goes away your fine. If the code stays there get it fixed but from what ive read your not going to hurt the engine.
pushbroom and spsauerland Thank this.
