C15, is it MPG and issues suicidal ?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Braazooka, Apr 21, 2010.
  1. Braazooka
    Braazooka Light Load Member
    70
    11
    Jul 1, 2009
    Orlando FL
    Guys, i'm considering to buy a truck with C 15 engine, its actually a ex-werner Shaker Classic, but i'm wondering how bad could be my MPG and other issues with this engine in particular.
    I would like to have opinions on this Caterpillar motor. C15, year 2005. How trouble it looks like for you ?
    I'm kind of lost in it. Truck looks cheap for it year/miles, i truly believe that nobody wants to get this truck because its a darn diesel sucker engine. Is that true?
    Appreciate any advice on it.
  3. Brickhauler
    Brickhauler Medium Load Member
    411
    142
    Oct 1, 2008
    Elizabeth CO
    I would be more worried about the fact that since it is a former werner truck there may have been a couple of dozen relatively inexperienced drivers in it. If that truck could only talk...
  4. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    I can only reply from rumor from countless drivers/owners of the c-15 cat. since I have never owned one. I dont know. however no one I have talked to had any good things to say about m.p.g. 4-5 m.p.g. ave is what I hear. I am sure there can be exceptions.
    Braazooka Thanks this.
  5. maxwelltie
    maxwelltie Medium Load Member
    416
    339
    Mar 13, 2010
    Brookings, OR
    I had a C-15 in my last truck. 2004 KW. got about 6mpg when I was REALLY carefull. Ran about 4.5 - 5.5 most of the time. But then I didn't buy the fuel then either.
    There are a couple service issues with the engine if it's 2007 or newer. Only had to replace the HUEI pump in mine, other than regular service. Engine was strong, but the cummins in the other truck we had got about 1 mpg better than the cat. I could out pull speed wise up a grade like the Siskiyous, but all in all, I'd go for a cummins.
    the other thing to think about is like another poster said... how bad was it mis treated? I don't know what Werner service is like. I've only heard rumors.
    I suppose if it had under 500M miles on it, I'd consider it for the right price, but I think Werner hangs onto them into the high 600's before getting rid of them.
  6. CMTrucking
    CMTrucking Light Load Member
    85
    27
    Dec 25, 2009
    Kamloops, BC
    What are you pulling, and where? I think it's safe to say you can expect anywhere from 4 - 6 mpg depending on conditions. I've seen as low as 3mpg with mine and as high as 6.7mpg. My brother bought an ex-werner '05 W900L, 430hp C15 turned up to 500, 9spd converted to 13spd, very tall geared (3.21?) on low profile 22.5s and he's getting a little better than 5mpg overall average. ECM said previous life time average was 6.9mpg, whether that's accurate or not is anybody's guess.
  7. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    a lot more to consider thna m.p.g. too. even if it has low mileage. some co's change their oil every 30- 40 thou miles. a MELTON DRIVER TOLD me they change oil every 30,000 miles. their trucks always look good, but the drive train maint, is more important to me.
    The Challenger and Braazooka Thank this.
  8. wire
    wire Light Load Member
    53
    19
    Mar 21, 2010
    Mb. Canada
    I have a C15 600bhp in a 2007 Pete 379. It is very reliable and pulls like a locomotive but the most mpg i can get is 5.5.
    On a bad day it can be worse. On a really bad day, a lot worse. (like 4.5).
    Cats are good for durability but if you want fuel mileage, definitely not.
  9. Braazooka
    70
    11
    Jul 1, 2009
    Orlando FL
    Thanks 4 all you guys, I plan to pull dry box or refer, anyway i don't need extra power required on heavy loads...The average mpg really surprised me, 5.5 at best? Huuu....with the current fuel price is something to think about...
    Everybody says about durability of this engine, that is pretty reliable, but how much it can be worth when you get 1mpg, 1.5 mpg less than comparing to other engines like DETROIT or CUMMINS...?
    i'm currently running a ISX Cummins, had a Detroit in a Cascadia and had also a CAT 15 on a KW 900...but always as a company driver, i never looked so closed about how much diesel those consumed...now that i'm turning to O/O that really matters....
    I feel attracted for the truck, specially for the price: $ 27k. for a shaker 2005 with 350k miles on it (ok, students # Werner screwed trans, but nothing is perfect...) but with the god #### C15 engine...that is the only point that make me get out of this deal...i don't know how...Do you guys think could be worth take a C15 considering the type of load i'm gonna pull X benefit of a strong engine?
    Thank you all!!
  10. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    I would go with a detroit. one thing to consider when getting advice & opinions on what type of truck to buy. big trucks are just like our experience with cars. people are loyal to the their first car that gave them great service. some swear by Ford, while other swear by G.M. e.t.c. same with trucks. I have had a great experience with my ser 60 detroit, that it is the only engine I recommend, based on my experience with it. though it is my first & only truck. so most folks response will be honest, it will also be biased. there is also the luck factor too. I read some where on this board where someone paid$3900 for the turbo's that went out on his cat. approaching 1.4 mil miles & my turbo is still original. replacement for my turbo is $575.00 a big difference. I will give you a tip that benefitted me. when I went from deep kelly lug tires on my drives to hiwy tires, I gained 1 m.p.g. the deep lugs went over 300,000 miles.the longevity could not be beat, but since I didnt run in mud or snow, I did not need them. the m.p.g difference was enough to stay with the hiwy tread.
  11. CMTrucking
    85
    27
    Dec 25, 2009
    Kamloops, BC
    Do yourself a favor and buy an older truck, pre-EGR. If you really want to get something '04 or newer, get the Cat but make sure you can afford to run at 5.5mpg because chances are that's all you will get. I wouldn't want to own any of these EGR engines.
