C15 Jake Popping under heavy loads or 1700 rpm?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 6NZoom, Apr 4, 2019.
  1. 6NZoom
    6NZoom Bobtail Member
    39
    13
    Feb 4, 2019
    British Columbia
    Hey everyone. I have an '01 6NZ that started popping with the Jakes on high today. Never did it before. Only seems to do it under heavy load at or above 1700 rpm. Any ideas?
  3. DieselTech_Aus
    DieselTech_Aus Light Load Member
    274
    309
    Dec 20, 2017
    WA
    does it pop on low or medium?
    can you hear the popping through the exhaust or more so from the top of the engine?
    I would be doing a valve set and jake adjustment ASAP and have a visual inspection while you're in there
    Oxbow Thanks this.
  4. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,471
    Nov 7, 2007
    Possum Booger, Alabama
    If it just started it today, you need to get the valve covers off ASAP and see if you have a jam nut that came loose. Then do an overhead.
    Oxbow and 6NZoom Thank this.
  5. 6NZoom
    39
    13
    Feb 4, 2019
    British Columbia
    I haven't tried it again since it did it last Thursday. Don't want to do any further damage. Overhead was just done 8000 miles ago. (Mechanic didn't torque the locknuts)
    Almost sounded like a backfire/popping sound. I have Jacob model 340B's on it, with the little cups on the bottom of the pushrods; maybe one came apart.
    I'll be opening it up tomorrow to check all the settings. Bought a Cat barring tool and Injector height tool today. Having a heck of a time locating a .033" feeler gauge though. Anyone know of a source?
  6. lilillill
    5,642
    13,471
    Nov 7, 2007
    Just stack two blades together to get .033
  7. 6NZoom
    39
    13
    Feb 4, 2019
    British Columbia
    Yeah, it just started yesterday. I'm thinking something backed off for sure
  8. lilillill
    5,642
    13,471
    Nov 7, 2007
    I had a Kenworth dealer almost smoke my NXS by missing broken rocker studs and misadjusting the jakes. I do all that myself now.
  9. DieselTech_Aus
    274
    309
    Dec 20, 2017
    WA
    if it sounded like backfire/popping then that may be a fueling issue. if for some reason the fuel wasn't getting shut off during jake application it will do that. same as when you manually apply them on the solenoid, the ECM doesn't know theyre applied so doesn't cut fuel.
    low is 3/4
    medium is 1/2/5/6
    high is all
    that can be a quick was to isolate a cylinder or jake housing.
    id strongly recommend getting tune up done. I personally don't torque the lock nuts either. I just do them firm by hand and touch wood ive never had one come loose. when the tune up is done with 340A/B/C/D jakes its important theyre all backed right off at the start and then adusted up to spec, purged, then locked up
    Oxbow Thanks this.
  10. 6NZoom
    39
    13
    Feb 4, 2019
    British Columbia
    Thanks everyone, for taking the time to reply. I've been given some great advice. I'll report my findings tomorrow
    lilillill Thanks this.
  11. 6NZoom
    39
    13
    Feb 4, 2019
    British Columbia
    Ok, so I checked the overhead today and found a few out-of-adjustment intakes, exhausts and Jakes. In fact, all the Jakes were loose by approximately .003 to .004 thou.
    I corrected everything and ran the engine. Tested all the Jakes via the solenoid buttons and they worked fine. I didn't find any oil leaks anywhere.
    I didn't get a chance to road test it yet, but possibly tomorrow or Monday. Guess we'll know then.
    Guess if it's still popping, I'll be rebuilding the Jake heads next weekend
    lilillill and SAR Thank this.
