C15 mxs breaking rocker arms
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Yves kanevil, Mar 22, 2016.
  1. Yves kanevil
    Yves kanevil Medium Load Member
    522
    465
    Jan 10, 2016
    Nighthawk
    Had my cat c15 mxs rebuilt with a platinum overhaul Las may. Truck ran great all summer and halfway through the winter started breaking rocker arms. 3rd one in a month and they always go while the engine break is being used What would be the cause. Is there a possible updated rocker arm. I'm at a loss here. Why all of a sudden am I breaking rocker when I never had problems before
    Thanks. Yves
  3. Al. Roper
    Al. Roper Road Train Member
    1,512
    10,725
    Apr 21, 2013
    Bakersville NC
    Does it have a weird kind of shimmy when the Jakes are on? Reason I ask, I have the same motor and had an overhead run. Before, Jakes on, no shimmy. After, shimmy. Found out there are 2 different thickness washers on the Jakes and if they are put back on wrong, it causes extra resistance which could break the rocker arms. Might be something else, but it might be something to check out.
    Oxbow Thanks this.
  4. Yves kanevil
    522
    465
    Jan 10, 2016
    Nighthawk
  5. Dub21
    Dub21 Bobtail Member
    10
    Mar 21, 2016
    The mxs doesn't have different washers for the Jakes. If you had a platinum kit installed at a dealer they should have checked for any rocker arm up dates. Did you have the valves reset after your first oil change? If the Jake setting gap was set to large it will increase cylinder pressure while jaking . Causing the rocker arms to break.
    Al. Roper Thanks this.
  6. Yves kanevil
    522
    465
    Jan 10, 2016
    Nighthawk
    Valves were re adjusted always breaking exhaust rocker. Cat saying must be a bad batch of rockers but I doubt it
  7. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,730
    Jan 30, 2010
    keep stroking.
    Over reving while using jake can cause them to brake also.
  8. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    This^^^
    I don't take any of my trucks over 1800-1900 rpm on the jake ever. Never had a top end issue in 25 years either.
  9. Yves kanevil
    522
    465
    Jan 10, 2016
    Nighthawk
    The truck never sees over 1700 rpm on jakes. It is always lugged under power.
  10. Al. Roper
    1,512
    10,725
    Apr 21, 2013
    Bakersville NC
    My MXS hasn't seen 1700. 1500-1550 bout the max. But I have a10 SPD, 3.55 rears and low pro 22.5's. Yours might be set up different.
  11. Yves kanevil
    522
    465
    Jan 10, 2016
    Nighthawk
    1700 rpm while using the Jake's. About 1600 while under load truck is geared for heavy haul 4.10 rears with 12 r 22.5 tires
