C15 MXS Conversion issue
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by ilovedetroits, Oct 13, 2018.
  1. ilovedetroits
    ilovedetroits Bobtail Member
    5
    Oct 13, 2018
    Hey guys I'm new here just looking for some help here, i have a 06 peterbilt 379 that has a mxs c15 and i just did a single turbo conversion, i used a borg warner 177148 turbo and a 6nz manifold, i got everything together and it starts and runs Good, has about 80 psi of fuel pressure, the issue I'm having is it only wants to make 20 psi of boost, i had the iva delete done and i backed all of those off and plugged the oil galley that feeds them, also unhooked the iva oil pressure sending unit, i have no check engine lights at all, anyhow it is turned up to about 580-600 now and i know 20 psi boost is to little for that and i have plugged the wastegate, checked cac and boots for leaks, it fuels hard till it hits 20 psi and then just stops fueling, BUT I was driving it around and shifted into the next gear and all of a sudden it had full fuel and made about 38-40 psi in boost but then i shifted again and back to 20 psi it went and i can't get it to full fuel any more than that one time, side note i took the resistors out of the boost wire that i had in there before any help is appreciated, some people have told me to try boost sensors it just threw me in a loop when it did full fuel that one time and made 40 psi any help is so so appreciated
    Oldironfan Thanks this.
  3. ilovedetroits
    5
    Oct 13, 2018
    I also have the coolant diverter valve solenoid unplugged if that matters i haven't tried hooking it up to see if that changes anything i will first thing monday
  4. Diesel Dave
    8,681
    24,685
    Jan 20, 2010
    Hesperia, Ca.
    Not trying to bust your bubble..... but your user name..... is not gonna help you much... us hardcore with yellow motors have pride......
    ilovedetroits Thanks this.
  5. ilovedetroits
    5
    Oct 13, 2018
    lol that was one i made before i saw the light years ago and I've just stuck with it its what i use on everything else
  6. Diesel Dave
    8,681
    24,685
    Jan 20, 2010
    Hesperia, Ca.
  7. Oxbow
    Oxbow Road Train Member
    12,787
    132,309
    Nov 24, 2015
    A few things come to my mind, but I am not as well versed as others.
    1. My 177148 gate opens at 24 to 26 lbs,
    2. The 177148 supports 550 hp; you may need a different turbo
    3. Pinching the wastegate hose may not be wise as it can overspeed the turbo
    4. I would be curious if you have progressive shifting parameters enabled in the ECM if it acts differently from one gear to another.
  8. spsauerland
    spsauerland Road Train Member
    4,296
    10,887
    May 31, 2010
    West Harrison, In
    Do you have Cat ET?
    SAR Thanks this.
  9. ilovedetroits
    5
    Oct 13, 2018
    No progressive shifting parameters and also wouldn’t pinching the hose make the boost come up though?
    Oxbow Thanks this.
  10. ilovedetroits
    5
    Oct 13, 2018
    No I don’t
  11. Oxbow
    12,787
    132,309
    Nov 24, 2015
    Yes, it should make the boost go up beyond what the gate is set at. 20# seems far too low so there must be something else going on. My 6NZ gets 30# with stock turbo and 475 factory ECM settings.
    One of the other fellas that knows a lot more about these things will be able to help.
    SAR Thanks this.
