Running a 2005 C15 MXS pulling 154,000lbs truck is equipped with 4.1 gears and 18 speed.
Has 13,000 hrs / 260,000 miles approx. Had the truck on the road about a year but it doesn't run everyday.
What I have done to date:
Changed 4 IVA's due to code / de-rate condition
New fuel filters as needed
Up-rated from 475hp to 550 HH (huge difference)
Fuel Temp wire
Adjustable boost wire (I run it at about 2-3lbs of "fake boost" helps the response at the stop light without much smoke at all)
Running down the road:
Boost PSI runs at 40psi on the ECM gauge with the "boost fooler" set to 0 when the pedal is down and RPMs are over 1500.
Fuel Restriction reading runs about 5 on the gauge.
Pyro will read about 1000, slightly more on a long hill pull.
Fuel PSI checked in the shop is about 97-98lbs at 1500+ RPM under no load.
Mileage runs about 3.5-3.8mpg
154,000lbs one way 45,000lbs back. My long route is about 140 mile round trip and a hard pull to get out there. Short route is about 40 mile round trip easy pull with 3 stopped to 60mph accelerations and 2 slowdowns from 60 to 45 to go thru small towns.
What I'm wondering is how these numbers look, and if there is anything I can or should do to improve them.
Thanks in advance!
C15 MXS heavy haul advice
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Diesel Dan 92, Aug 17, 2018.
Page 1 of 3
@superhauler might have some suggestions. To me boost looks a little low.
Oxbow, drdesl, SAR and 1 other person Thank this. -
Your numbers on the air intake restriction at 5 is BEAUTIFUL. As long that dial and yellow column does not pull too much more than say 10 or more into the yellow zone towards the top range you are good. If you get towards 7 on your air restriction, consider a new filter as required until your engine can breathe at 3 to 5 again.
Mr PYRO on the upgrade at 1000 tells me you understand how to pull it without abusing the engine. It proves to me you know how to put the engine into a certain sweet spot for the pull upgrade with that weight and it will get to the top without too much fuss trouble or problems in time.
HOWEVER if you start seeing Mr Pyro say 1250 and above, you need to back off it, you CAN for a few minutes take a 1400 or so thermal load if you must. But do not make a habit of it.
I worry about you feeding the turbo. Are you trying to pre-boost it or make it spool up before you really need it? I imagine you attaching a fast RPM electric motor to the Turbo's wheel and spool it faster at idle before you press down the fuel pedal when you do, the electric motor should disengage and your turbo should freely boost having already reached a goodly amount of RPM.
That last paragraph is just a imaginary on my part. I don't understand what precisely you mean about fake boost on a turbo. All turbos I understand will boost to a certain amount when you get to that point on the engine because it's exhaust driven.
What I think you might benefit from is actually superchargers. But I don't know of anything or anyone in heavy big trucks running those.
These are just my basic question for now. Depending on how you teach me about the details of your turbo issue we might talk more.Zeviander Thanks this. -
Your boost does seem a little low. Also your pyro is a little high. This tells me you should check the air to air and everything over good . Pressure test the whole system.
Other then that the rest seems fine. -
I ran a 2006.5 NXS C-15 for almost two years up to 137,800 lbs with Super-B trains. 3.73 rears, 18-speed, 46k rears, 550hp/1850lbft.
You pyro temps seem about right for that weight (700-900 is "normal" for pulling heavy with all the N/M/BXS CATs I've driven). Boost is is a touch low (mine ran up to 45 under full fuel). Fuel mileage for me was between 3-4 mpg on summer fuel (I could get 6.4 at 80,000 gross).
Sounds like she is running just fine. -
Advance the timing a little and up the fuel.....
CATERPILLAR Tuning & Performance | 3126 Highway Truck -
Oxbow Thanks this.
Page 1 of 3
