C15 oil in coolant
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 4x4_Welder, Jan 9, 2018.
  1. 4x4_Welder
    4x4_Welder Medium Load Member
    300
    213
    Sep 16, 2014
    Eastern Orygun
    2004 KW T600 with a C15 Acert-
    There is a truck at the shop with an oil in coolant issue. Another tech just did the oil cooler, and in the first drain during flushing the emulsified oil/water mix came out as expected, topped by about a cup of nice fresh engine oil.
    Now, with a new oil cooler, where does this leave as an oil intrusion point? Is there an o-ring in the head or something?
    VWbeagle Thanks this.
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,193
    6,011
    Aug 26, 2014
    Transmission cooler?
  4. 4x4_Welder
    300
    213
    Sep 16, 2014
    Eastern Orygun
    I'll have to explore that potential, although the engine was three gallons low on oil when it came in. I will pull the trans check plug tomorrow and see what's in there.
  5. Dave_in_AZ
    315,918
    Just 3 gallons?
    @wore out any ideas?
  6. 4x4_Welder
    300
    213
    Sep 16, 2014
    Eastern Orygun
    Local haul fleet trucks, lack of maintenance is to be expected.
  7. wore out
    wore out Numbered Classic
    14,343
    174,022
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    I would recheck the oil cooler job, if your sure it's engine oil
    SAR, Dave_in_AZ and Oxbow Thank this.
  8. pushbroom
    pushbroom Road Train Member
    1,769
    7,205
    Sep 1, 2012
    Trans cooler gives a more brownish oil in the rad tank as opposed to the black of engine oil. If you are sure its engine oil and the oil cooler was rechecked, next would be water pump or head. Both highly unlikely.
    spsauerland Thanks this.
  9. pushbroom
    1,769
    7,205
    Sep 1, 2012
    Oil left over in the bunk/ accessory coolant lines that did not get flushed out from the first failure?
    Caterpillar Cowboy, Oxbow and wore out Thank this.
  10. 4x4_Welder
    300
    213
    Sep 16, 2014
    Eastern Orygun
    I'm not sure about leftovers, this truck came in with a complaint of the heater not working. The heater didn't work because the cooling system was full of the nastiest sludge I have ever seen. It was like brownish mayo, especially in the way it didn't separate. The system was completely full of this stuff, after two days the radiator was still drizzling out a stream of it, we had to have the radiator rodded out. The pan of drained goo has been sitting two weeks and has not separated, so I wouldn't think there is a pocket of oil left in there.
    The engine does have fresh clean oil in it, and the oil that drained out on top of the flushed material was a nice honey color.
  11. Dave_in_AZ
    315,918
    Kinda like they knew the oil cooler was blown, but went look it still runs, so what's the big deal?
