I was wondering if someone could break down this number. It is 2707067-00. Also I had my injector codes sat at 5232, sa2w some improvement, would like to know how to do fuel temp mod. This is a c15 6nz serial number.
c15 personality module info and fuel temp mod info
Discussion in 'Trucks [ Eighteen Wheelers ]' started by stretch69, Oct 19, 2011.
475 hp at 1800 rpm, 1650 peak torque at 1200 rpm
475 hp at 2100 rpm, 1650 peak torque at 1200 rpm
475 hp at 1800 rpm, 1750 peat torque at 1200 rpm
475 hp at 2100 rpm, 1750 peak torque at 1200 rpm
This file allows you to choose one of these 4 hp, rpm, and torque ratings by programming the Standard Rating Number in the Customer Parameters. The Standard Rating number can be numbers 1, 2, 3, or 4 listed in the Configuration File/Customer Parameters. Most of the time they'll be programmed to 475 hp at 2100 rpm with the torque rating matching the transmission torque rating -
Thanks for the info. I believe it is set for 475hp at 2100 with 1750 torque at 1200rpm.
the resistor mod doesnt add any noticeable power anyone who tells u it does is a liar have a '01 6nz 500 turned to a 550 with 5232 injector codes and all the plug does is make it smoke so bad the EPA will issue a warrant for ur arrest
I build them and sell them, but if you do a search for it on the forum, you'll find your answer.stretch69 Thanks this.
