C15 SDP Valve seals
Discussion in 'Trucks [ Eighteen Wheelers ]' started by dr1c, Aug 16, 2018.
  1. dr1c
    dr1c Light Load Member
    75
    11
    Apr 10, 2011
    Alberta
    Hey Guys,
    Have SDP Cat with a single turbo conversion at work and keeps putting oil into cylinder and leaks out exhaust
    manifold. If the guy that put factory piston packs back in on rebuild and deleted IVA's I think that would be too much cylinder pressure? Already blew valve seals once.I thought you need to leave IVA unless you drop compression in these motors?
    Thanks, any info helpfull.....
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,525
    6,586
    Aug 26, 2014
    What keeps putting oil in the cylinder? Turbo? How do you know? Bad air filter?
    I thought valve seals were there to prevent to much oil from seeping down the stems. Causing a little oil usage or smoking on start up like old high mileage Chevys often did. Some engines did not come with valve stem seals and others only had them on the intake.The clearance between the stem and guide should be close enough to control pressure into the crankcase.
    I also thought to much cylinder pressure blew head gaskets and or caused excessive cylinder temperatures.
    Cannot talk about deletes here but I thank you are chasing the wrong horse.
    We can talk about engine theory and the results of a malfunctioning IVA.
    magoo68, SAR, maggard359 and 1 other person Thank this.
  4. dr1c
    75
    11
    Apr 10, 2011
    Alberta
    Fair enough...my bad
  5. wore out
    wore out Numbered Classic
    16,724
    204,645
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Valve seals on a CAT?
    Oxbow and SAR Thank this.
  6. bigdad7
    bigdad7 Road Train Member
    1,837
    1,364
    Jun 6, 2010
    ks
    I was told on thesdp the effects on a malfunctioning iva setup are bad ...best to do a tune that uses the ivas ....lots of blown heads from "malfunctioning ivas"
    Oxbow and wore out Thank this.
  7. bigdad7
    1,837
    1,364
    Jun 6, 2010
    ks
    Check out Larry's diesel in Frontenac KS ....great certified cat shop but also used to be a pdi dealer....only person that I allow in my engine anymore and is only 99 an hr
