C15 stopped dead on hiughway
Discussion in 'Kenworth Forum' started by bluezman55, Feb 10, 2014.
  1. bluezman55
    bluezman55 Bobtail Member
    friend of mine drives a 2003 kenworth wit C15 475 logging truck going down highway just stopped dead didn't sputter or anything just stopped dead still on side of road battery are good fuel is good but won'tfire thinking maybe the CPU any ideas
  3. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    sensor on front timeing cover on drivers side,when bad no code its like turning off key.
  4. DrivingForceBehindYou
    DrivingForceBehindYou Medium Load Member
    546
    184
    Aug 29, 2012
    ChicagolandOfOpportunity
  5. EverLuc
    EverLuc Light Load Member
    295
    101
    Feb 18, 2013
    Someone else on this forum had a problem getting a C15 to fire in a Kenworth. I believe it was SMELLSFUNNY. It turned out to be a lead from the starter to the ECM. I own a 379exhd and my Acert shut off w/same description as you have given. Turned out to be the 5 amp fuse that runs to the ECM. It had worn loose. Wiggled it and truck would fire up, wiggled it and truck would shut off.
  6. Chris50
    Chris50 Medium Load Member
    346
    215
    Jun 21, 2010
    Florida
    Mine did the same as Everluc....Should be 3 smaller wires ,10-12 gauge, with inline fuses going to positive terminals of battery, check them
  7. bluezman55
    great thanx for the replies
  8. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    mine did the same thing one time. was a wire that connected from starter came out of the crimped end.
  9. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    actually was from the starter selnoid.
  10. Jesse_James
    Jesse_James Bobtail Member
    24
    8
    Sep 1, 2013
    Mine did the same thing. Had it towed into cat. Turned out to be a wire to the ecu. I would start checking wires.
    EverLuc Thanks this.
  11. JW Trucking
    JW Trucking Bobtail Member
    34
    Mar 14, 2011
    MT
    Had an ecu go out on me same results.
