C15bridge info?please
Discussion in 'Kenworth Forum' started by Bkhatch76, Mar 16, 2013.
  1. Bkhatch76
    Bkhatch76 Bobtail Member
    I have recently bought a 2004 W900L KW with a C-15 bridge motor and the oil pressure is running about 68 psi warmed up running at 1500rpm also the water temp is running at 185 empty and 200 to 210 loaded and the fan never shuts off doesn't matter cold or hot.Dose anyone know if this normal.Any info on this motor is helpfull! Thanks
  3. bstromback2002
    bstromback2002 Light Load Member
    133
    24
    May 12, 2012
    wi
    Probably needs the fan clutch solenoid that delivers the air to the clutch to release it. Its probably mounted on the firewall just follow the airline from the clutch and you should be able to find it.
  4. bubbanbrenda
    bubbanbrenda Road Train Member
    1,388
    650
    Feb 27, 2011
    Middletown,Oh.
    what he said, check the lines for leaks also.
  5. rollin coal
    rollin coal Road Train Member
    13,280
    26,776
    Mar 29, 2008
    TN
    Those temps sound about right. When you get the fan problem fixed it'll routinely go up to 217 before the fan kicks on if you let it. You probably see crazy high egts too. The only way to fix any of that is to unbridge. The cheapest fix would be to get a 6NZ flash from Haney, upgrade the turbo then you'll have normal temps, better power, economy..
  6. j-dawg
    j-dawg Light Load Member
    164
    47
    Dec 21, 2011
    Oil town, Ab
    Probably late but if the fan is running all the time sometimes the a.c. high temp switch is faulty. If you can find the switch, unplug it a use a jumper wire to cross the terminals. If the fan shuts off its very likely the switch or the a.c is not charged.
