C16 Cat motor married to spicer 6x4
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Thefugitive, Sep 7, 2018.
  1. Thefugitive
    Thefugitive Bobtail Member
    Sep 7, 2018
    Hello, I am an owner of a small 6 truck peterbilt fleet. Currently, all my trucks are 2014 or newer 389’s. However, I recently ran across someone that had a 2011 Peterbilt 389 glider with a c16 motor. The motor has all new parts on it and has only been in the truck 4 months. The transmission is an 18 speed and itneeds replacing. I have an spicer 6x4 sitting in my garage; wanted to know is this too much torque for that tranny? The truck is almost show quality and would only be driven by me twice a week for maybe 1600 miles. Any thoughts would be appreciated. Thanks
  3. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    It's a C-15 in video. All depends on your right foot. Many a 9513 or 12513 lived behind some hot motors.
  4. wore out
    wore out Numbered Classic
    16,755
    205,039
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    I agree it's all in your right foot. I have seen a set of boxes behind several 3408 CATS and KTA Cummins that were big horses.
    snowman_w900, bigguns, Oxbow and 4 others Thank this.
  5. RSB34
    RSB34 Light Load Member
    277
    198
    Feb 9, 2013
    ny.
    I love that Amodel it pops up every once in a while on Facebook and other outlets. It’s just a gorgeous piece of old iron.
    bigguns, Oxbow and wore out Thank this.
  6. mtoo
    mtoo Road Train Member
    1,936
    4,514
    Jan 15, 2011
    Retired on bended knee
    If your a good driver and easy on equipment, then no problem. Some abuse in the lower gears and weak link will show up.
    As far as torque ratings go, a C15 set @ 475HP and 1650 torque is more torque than its rated for.
    A stock C16 is 600HP 2050 ft lb torque, the spicer PSO140-6A is rated for 1400 ft lbs torque. the old spicer 1241 4 speed aux is rated for 12,000 ft lbs. In 1st gear 7.47 x 2,050 = 15,313 ft lbs going into the aux trans.
    This says on paper it does not work, in the real world, with "top shelf" drivers it works just fine.
    We need to know what transmissions are laying in the garage, there is a AMO 1750-4 rated at 17,000 lbs
    snowman_w900, DougA, bigguns and 3 others Thank this.
  7. Oxbow
    Oxbow Road Train Member
    13,378
    138,605
    Nov 24, 2015
    Can the moderators merge this thread with the other? Thanks
  8. 25(2)+2
    18,756
    45,806
    Sep 18, 2006
    the road less travelled
  9. Oxbow
    13,378
    138,605
    Nov 24, 2015
    Thank you!
    25(2)+2, snowman_w900 and SAR Thank this.
  10. Thefugitive
    Sep 7, 2018
    Thanks a lot guys for the input. However, I have a spicer pso140-6a main box and auxiliary is a spicer 1241 4 speeds. Any thoughts?
    snowman_w900 Thanks this.
  11. mtoo
    1,936
    4,514
    Jan 15, 2011
    Like I said, on paper it does not work. That 6 speed is rated @ 1400 ft lbs, a 600HP C16 is putting out 2050 ft lbs. The 1241 spicer is rated at 12,000 ft pounds, in 1st gear you would be putting 15,313 ft lbs into it.
    On paper both boxes are to weak to handle a C16.
    In the real world, with a good driver both boxes would last a very long time. Myself and some others on this forum would love to have that setup and would not be scared to work it.
    You seem to be unsure of yourself, that is a huge amount of torque, things can go bad and get expensive fast. Since you don't have a burning desire for the 6x4 two stick, then just replace the 18 speed. It's made to handle the big horse. Enjoy the show quality pete with the C16 big horse.
