Cab swivels
Discussion in 'Volvo Forum' started by jpracer1, Feb 8, 2017.
  1. jpracer1
    jpracer1 Medium Load Member
    439
    198
    Nov 26, 2009
    2000 770 and the cab swilwea
  3. boneebone
    boneebone Road Train Member
    2,296
    2,367
    Mar 13, 2009
    What do you mean Cab Swivels, can you give more descriptive details?
    CoyoteExpress Thanks this.
  4. arrogant steve
    arrogant steve Medium Load Member
    444
    463
    Mar 31, 2016
    East Texas
    Cab swivels!? WTF!
  5. jpracer1
    439
    198
    Nov 26, 2009
    I have full fenders and noticed when i turn left at some speed the back of my cab goes to the right thinking it is right front cab mount
  6. KB3MMX
    KB3MMX Road Train Member
    3,069
    2,589
    Dec 29, 2014
    Orrstown, PA
    You really should do a better job of describing what's going on when you post it.
    However, it sounds like you just need to replace the cab mounts, not a big deal
    You should also replace the shock absorbers at the same time and if it has the torsion bar you should put a new one on.
    Crude Truckin' Thanks this.
  7. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    You probably have the old style set up with 4 shocks which are pos the best way to go is update with new Volvo set up two shocks and a torque rod. Not hard to do just need to maybe drill 4 holes for the torque rod Mounts in the bottom but definitely need can mounts as well
    KB3MMX Thanks this.
  8. jpracer1
    439
    198
    Nov 26, 2009
    Nasriza do you have the part number for that?
  9. boneebone
    2,296
    2,367
    Mar 13, 2009
    You can get the VIN# on a VNL780 and use it to obtain the Part# from the Volvo Stealership.
    I have 2001 Volvo 770 and I'm going to replace the Cab Bushings and eventually upgrade to the Torque Rod setup.
    KB3MMX Thanks this.
