Here's the info I have:
at 1400 RPM I'm running 58mph
at 1450 RPM I'm running 60mph
The truck has 22.5 tires (not lo-pro) & a 10-speed Rockwell Transmission behind a Mack factory engine (unsure of the model of the engine).
Any guess as to what the rear gear ratio is?
Calculating Gear Ratio?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by gummy bear, Dec 24, 2009.
Couldn't tell you for sure, but the best way to find out is on a flat surface, have someone else move the truck forward one tire turn and count the driveshaft revolutions. Then you know for sure.
Usually there's a label on the drivers side door opening on the back side telling you what's in the truck. -
I will try to post a link to roadrangers ratio site but you need to know the trans ratio or check the revs in direct http://www.roadranger.com/ecm/groups/public/@pub/@eaton/@roadranger/documents/content/ct_062746.swf
Mack rears or eaton's my SWAG would be 3.87 or 3.90 Mack truck will not have a tag on the cab but will be stamped or a tag on the rear end, or Mack parts man can tell you, all you need is last 6 of the vin
http://www.richmondgear.com/101032.html According to this web page it would be about a 3.08 or lower
Mack truck with 3.08 gears and a direct drive rockwell I highly doubt it
gummy bear Thanks this.
normally mack ratios would be out compared to normal rears like 3.87 or 4.17 and so on, i use to love em
