California..overweight vs over length
Discussion in 'Experienced Truckers' Advice' started by Upinsmoke, Nov 7, 2019.
  1. Upinsmoke
    Upinsmoke Medium Load Member
    612
    1,206
    Feb 26, 2019
    Reading 34,500 on the tandems with them all the way forward.
    Moved the tandems back 2 holes..12 inches.
    Am I legal in a utility reefer trailer?
    No 40 ft markings on the trailer and I don't have a tape measure.
    Would you rather run 500 pounds overweight with tandem forward or run weight correct and possibly be 12 inches too long?
    Thanks.
    tank4life and Flat Earth Trucker Thank this.
  3. Flat Earth Trucker
    4,133
    15,466
    Nov 19, 2018
    If you are pulling a 53 footer, you must set your trailer tandems to at least the 40 ft mark or further forward.
    You will be stopped at a California to correct this. CHP is big on the 40 ft mark. CHP will have a tape measure on hand.
    If you are still overweight and are unable to correct the weight, you will sit parked until that load is reworked. Two or three hundred pounds over they might forgive, but more than that earns you an overweight fine.
    LoSt_AgAiN, Upinsmoke and okiedokie Thank this.
  4. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    I don't guess there is any right answer, but personally I would go with the over length. At least they will have to be paying a little more attention to notice it.
  5. Upinsmoke
    612
    1,206
    Feb 26, 2019
    I counted the holes from back of trailer= 31.
    1st hole to third hole is 12 inches or one foot.
    I should be ok in the third hole if my math is right.
    Someone scratched a mark into the trailer which makes me think I'm ok.
    Maybe the banning scales will be closed?
    :biggrin_2559::biggrin_25523::laughing3:
    Flat Earth Trucker and D.Tibbitt Thank this.
  6. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,135
    Mar 5, 2016
    White County, Arkansas
    Well, if you are ###### if you do and ###### if you don't pick the least painful penalty.
    Find a way to burn off that 500 in fuel right quick.
    Upinsmoke Thanks this.
  7. Upinsmoke
    612
    1,206
    Feb 26, 2019
    I'm 32000 on the drives..hardto burn fuel off the tandem..lmfao..
    ncmickey, D.Tibbitt and x1Heavy Thank this.
  8. x1Heavy
    34,017
    42,135
    Mar 5, 2016
    HA ok So I stepped into that one. My bad.
    What about that5th wheel?
  9. D.Tibbitt
    147,889
    U can run the banning scales no problem if ur feeling adventerous, u wont be the only one doing it i can tell you that. Or find a lil group of trucks thats bypassing and run with them and blend in. Or face the misery and test your luck on the scale . good luck to you
    Flat Earth Trucker and Upinsmoke Thank this.
  10. Upinsmoke
    612
    1,206
    Feb 26, 2019
    5th wheel is stationary..thanks to past drivers who like to bend fairings like pop cans...
    Lepton1, D.Tibbitt and x1Heavy Thank this.
  11. x1Heavy
    34,017
    42,135
    Mar 5, 2016
    Here is my final set of cards (Idea) is trailer sealed? Maybe move half a pallet forward?
