Can’t sit in drivers seat for extended periods without aching.
Discussion in 'Questions From New Drivers' started by Zonno, Aug 26, 2025.
  1. Zonno
    Zonno Medium Load Member
    327
    204
    Jun 11, 2018
    South Ga
    This isn’t WebMD, but I’m posting this to ask if this has happened to anyone else, and more importantly, did they recover??
    I’ve gotten to where when I’ve been sitting for only about an hour, my buttocks and lower back start to ache. Getting out to stretch will provide temporary relief, but in around 20 minutes or so I start to ache again. I’m thinking what may have caused this is driving and sitting on an old, hardened seat in which the padding and cushioning was worn. They’ve since replaced the seat, and I also invested in a $170 purple cushion. Both those things have helped, but it seems like it’s only getting worse despite it. I’m not to the point of not being able to drive YET, but it’s going to come to that point if this continues. Even driving my personal vehicle or sitting on the sofa at home; about 20-30 minutes and I have to get up.
    Looking up the symptoms, I don’t think it’s Sciatica, as it’s not a burning sensation and there’s no tingling or numbness. Also when I get up my lower back is still a bit sore and stiff but otherwise I’m fine. Has anyone had this problem and if so, what was the diagnosis?
    tscottme and Ribeye Thank this.
  3. Kyle G.
    Kyle G. Road Train Member
    3,901
    20,571
    Jan 23, 2016
    Eastern Iowa
    I've had the same problem for years. I always just assumed it's because I am so tall. When I was in a daycab at my last job, I talked the boss into buying me a slightly larger aftermarket seat, that helped a little.
    Now I am in a truck with a sleeper and more leg room, so it's much better. But still am only good for a couple hours max in the seat. Good thing I'm paid by the hour!
    77fib77, austinmike and Zonno Thank this.
  4. Zonno
    327
    204
    Jun 11, 2018
    South Ga
    Thanks for this Chinatown! Looking it up, mine is more in the lumbar region on both sides.
    Chinatown Thanks this.
  5. Zonno
    327
    204
    Jun 11, 2018
    South Ga
    I’m 6’3” and also drive a daycab.
    Kyle G. and austinmike Thank this.
  6. bad-luck
    bad-luck Road Train Member
    3,359
    6,211
    Nov 16, 2013
    Baltimore, Maryland
    A worn out seat, or a seat that you can't seem to get comfortable in will do that.
    Ribeye and Zonno Thank this.
  7. MACK E-6
    49,638
    233,982
    Have you tried adjusting it? You should be able to pull the bottom portion out a little, and adjust its incline. I did with mine.
    Numb and Zonno Thank this.
  8. cuzzin it
    cuzzin it Road Train Member
    3,638
    11,236
    Jan 19, 2008
    Berea, KY
    Taking into consideration of this and some previous posts of yours. I would suggest you look into a differant line of work.....
    Perhaps RC Gorman would be a better employer with the trains instead of trucks
    Ribeye Thanks this.
  9. xsetra
    xsetra Road Train Member
    5,161
    7,092
    Aug 21, 2011
    This type of discomfort I get every time the mechanic moves the seat to drive. I have to adjust the seat multiple times to get it "right".
    In my current truck I tried 3 different new seats, I ended up putting the original chair back in. Adjusting it to and away from dash also height.
    Until I find the exact spot. I adjust the seat when the pain starts. Once I find the spot, I drive all day with no pain.
  10. Arctic_fox
    4,351
    23,444
    Sep 16, 2016
    Mine was always a mix of a crappy seat and being 6'2 with long ### legs. When i got a nice seat for my peterbilt a lot of the pain went away. What ive found is the seat pad usually is not long enough and these seats arent tall enough so my legs force me into a slouch. So getting one thats longer or adjustable as well as one that rides at a comfortable height helps a ton.
    Also your wallet? Ditch it.
    tscottme, Numb and Zonno Thank this.
