can a regen affect my shifting rpm
Discussion in 'Questions From New Drivers' started by jodycmacneil, Jun 22, 2016.
  1. jodycmacneil
    jodycmacneil Bobtail Member
    I am new to tractor driving but today as the truck was regening it was harder to get the gears I was shifting up at 1300 to 1400 like every day but harder to get it in gear while regen
  3. A21CAV
    A21CAV Road Train Member
    1,848
    2,156
    Oct 4, 2011
    Laredo, TX
    If the fan clutch was engaging due to the regen overheating the engine it will cause the RPMs to quickly drop between gears . The truck will shift like you're taking way to long between gears and mis-matching RPM , gear and road speed .
    akfisher Thanks this.
  4. jodycmacneil
    thank you
  5. Upright
    Upright Medium Load Member
    643
    461
    Jul 13, 2012
    California's Best City
    Trick to this, to get it in gear without grinding, you slightly accelerate while shifting keeping the rpm up as you shift to next gear.
  6. iceman32
    iceman32 Medium Load Member
    564
    699
    Sep 26, 2014
    Regen system does all kinds of weird things to the engine. And each engine of every truck is different, some will shift at high rpm when you climb, and some will shift at a low rpm.
    If the truck is done doing a regen but has not emptied all the smoke from the exhaust or burner, then you will have low boost pressure that will quickly drop, so shift at higher rpm.
  7. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,135
    Mar 5, 2016
    White County, Arkansas
    And I guess you want to look for a place to rest while regenning.
    I never had a regen, but imagine the losses in power is enough to go get lunch while the #### thing does it.
  8. MACK E-6
    48,716
    224,842
    How long does this operation typically take?
  9. cumminskid123
    cumminskid123 Light Load Member
    107
    59
    Jun 21, 2016
    Manitoba, Canada
    depending on the engine, anywhere from 45 mins to 2 hours... ive had some d13 volvo engines take 30 mins. providing that the system is working properly
  10. bowtieboy77
    bowtieboy77 Light Load Member
    274
    82
    Aug 16, 2013
    Southern, Ontario
    As stated above the stationary regens take about 30 to 45 mins. When the truck regens going down the road you really wont even know its doing it except mayby the shifting as you stated and sometimes a "hot" exhaust smell.
  11. flood
    flood Road Train Member
    4,161
    4,031
    Dec 25, 2010
    one of the reasons it's harder to get the shift right is when it's doing a regen the system wants to keep the rpm's up.... they don't drop as fast
    the Volvo we had we could always tell when it was doing a regen because the tone if the engine/exhaust would change. it just took a haft a tick longer (you'll get it).... it's a timing thing and it not the same for every truck
