Can any help? Trailer issues
Discussion in 'Flatbed Trucking Forum' started by Jeck, Jul 11, 2017.
  1. Jeck
    Jeck Light Load Member
    167
    105
    Feb 22, 2017
    When loaded the box touches the back tire. I think I need to take the box off or move it forward. Just not sure it there is anything else I can do. The load is 48k
  3. LoudOne
    LoudOne Medium Load Member
    I'd be looking at placement. How much room do you have in front of it?
    Jeck Thanks this.
  4. zinita17601
    zinita17601 Road Train Member
    1,318
    1,603
    Aug 19, 2010
    lancaster pa
    If u got a 2 inch ratchet strap,put it around the box and pull it away
    Jeck and baha Thank this.
  5. LoudOne
    That will work as a temporary fix.
    Do you have other mounting holes where it is for a permanent fix? Is it your trailer or company trailer?
    Jeck Thanks this.
  6. AModelCat
    161,678
    I bet those tires are bigger than the ones it rolled out of the factory with. Best bet is to slide it ahead an inch or 2 as a permanent fix.
    x1Heavy, Jeck and LoudOne Thank this.
  7. nasriza
    nasriza Road Train Member
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    tires are 11r22.5 if you put low pro 22.5 should solve your problem or move the boxes to a different position.
    Jeck Thanks this.
  8. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    Did you just buy the trailer? Or mount the boxes? Make sure there's no structural damages and then move the boxes as needed.
    Jeck Thanks this.
  9. Check the alignment pin on that side of trailer. Did your trailer hit any monster potholes? Or curbs by chance?
    wore out and Jeck Thank this.
  10. Brandt
    Brandt Road Train Member
    4,609
    6,329
    Sep 17, 2012
    I say same as other post wrong size tires or load leveling valve.
    Jeck Thanks this.
  11. Jeck
    167
    105
    Feb 22, 2017
    It really depends on the load. I have rebar on now. Still weighed in at 79k. I don't use the box. I bought the trailer used a month ago and put a quick draw on it. So no need for the box. There is room in front so maybe when I have time I could put new holes and move forward. But I'm on the road right now and really have no choice to drive.
    daf105paccar Thanks this.
