can compressor be "stuck on"
Discussion in 'Trucks [ Eighteen Wheelers ]' started by clhart426, Nov 11, 2013.
  1. clhart426
    clhart426 Bobtail Member
    43
    Dec 15, 2011
    Toledo,OH
    This is sort of an update to my air dryer purge problem. Ive plumbed shop air to my hose that comes out of the compressor. I start the truck, and then turn on shop air. Once the systems to pressure, it purges. Ive also pulledcthe line off the compressor coming from the governor. I'm getting pressure there. Hook that back to the compressor/unloader, and don't feel any difference in the pressure coming out of the compressor-like it was being "shut off". I pulledcthe new unloader out of the compressor, stuck my finger down in there and felt "carbon" looking stuff at the bottom "seat". I wire brushed it out, reassembled, it acted better and then did the same thing. SO, after all that said, lol, is it possible that the internals of compressor are bad and causing it to never unload/shut off, or is that not really what's wrong
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    broken unloader line (1/4") ore bad unloader... just IMO
  4. QUALITYTRUCK
    1,801
    1,762
    Jun 14, 2009
    romulus,mi
    if you have a detroit 60 egr engine you must remove compressor head,seperate all 3 pieces and clean well.bendix part#5008558 gaskets/#5008557 unloader kit.re assemble carefully.done.good luck.
  5. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    as remember there is one cylinder knorr bremse compressor... our, branded as bendix... really simple and easy to fix
  6. clhart426
    43
    Dec 15, 2011
    Toledo,OH
    Awesome. Thanks for the responses. Im in the process of swapping out tuec1/4" line just to be safe. It is a d detroit egr s60. So at least now I have part#s and a sense of direction with it
  7. d281833
    d281833 Heavy Load Member
    881
    919
    May 15, 2012
    Mine was the unloader valves in the compressor, just swapped out and it was fine.
