Can Have a trailer axle with grease one side and the other side with oil?
Discussion in 'Trucking Industry Regulations' started by Ivan1817, May 18, 2022.
  1. Ivan1817
    Ivan1817 Bobtail Member
    4
    Mar 10, 2021
    Can Have a trailer axle with grease one side and the other side with oil? I just changed the hub seal on my trailer but it kept leaking a lot of oil so the mechanic suggested to change from oil to grease on that side of the axle. I was wondering if it was legal and is it ok to drive with grease hub one side and oil on the other side.
  3. Big Road Skateboard
    6,261
    34,513
    May 2, 2021
    Yes it's legal, and yes your mechanic sucks.
  4. Another Canadian driver
    Another Canadian driver Road Train Member
    1,181
    4,264
    Nov 14, 2021
    ALBERTA
    Yes.
    Ivan1817 Thanks this.
  5. FLHT
    FLHT Road Train Member
    1,397
    2,452
    Aug 2, 2014
    Something must be bent...
    Grease will get hot and you will have grease seeping out at some point
  6. ZVar
    ZVar Road Train Member
    10,911
    23,828
    Sep 10, 2010
    Flint, MI
    While you can, there is a reason it keeps leaking. If the mechanic you are using is unable to fix it, I suggest looking for another mechanic.
    Just patching the symptoms doesn't fix the problem.....
    Bean Jr. and wis bang Thank this.
  7. Arctic_fox
    4,104
    21,284
    Sep 16, 2016
    Bean Jr. and InTooDeep Thank this.
  8. SmallPackage
    5,494
    17,485
    Dec 20, 2019
    Marion Texas
    It’s done all the time. Sometimes that's the only way to fix the situation. Seals not available at the time, porous or worn spindle surfaces that will allow oil to pass no matter how tight the seal is. Perfectly safe and cheaper than replacing an axle that is still just fine.
  9. Ivan1817
    4
    Mar 10, 2021
    thanks everyone for the help but yes, it was a bent or cracked spindle that's why it kept leaking even after putting on a new seal. I first got it fixed in a small shop, but it kept leaking after a day, so I had it replaced again at a different shop where they changed it to grease. The first place must have messed with it , but I was far and I couldn't get a refund smh
  10. FLHT
    1,397
    2,452
    Aug 2, 2014
    Axel surgeon can fix that....$$$$$$$$
    Bean Jr. and Big Road Skateboard Thank this.
  11. Rideandrepair
    17,350
    56,291
    Aug 8, 2015
    I hope so. I have oil in 1 hub, grease in the other 3.
