Can I fix this dry van wall without replacing the whole panel?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by GlassRoots, Sep 9, 2021.
  1. GlassRoots
    GlassRoots Bobtail Member
    13
    21
    Mar 7, 2015
    I've got a little experience working on sheet metal, but not on dry vans. With those tears being right up against the edge, it doesn't seem like I could rivet a piece in. Is there a way for me to patch that without needing to replace a whole panel?
    This is a trailer I'm considering buying and just want to know what I'll be in for on the repairs.
  3. Slowpoke KW
    Slowpoke KW Road Train Member
    1,170
    12,826
    Dec 7, 2015
    OK
    Yeah just section it
    Goodysnap, Magoo1968 and Rideandrepair Thank this.
  4. Rideandrepair
    17,449
    56,619
    Aug 8, 2015
    Patch it. Looks like you might be able to tuck it in under the rail at top. Nice white square patch. Won’t even notice it,
    Slowpoke KW Thanks this.
  5. Magoo1968
    Magoo1968 Road Train Member
    2,050
    5,466
    Mar 18, 2021
    St Malo mb
    Judging by the other bruises I’d carefully check roof as well.
  6. jamespmack
    216,333
    Being sheet and post. Proper way would be cut out post,to post. Remove rivets low enough to slide new patch pannel in from behind. Then buck it in. Thin bead of silicon and roll.
    Pop rivets are not made for this and are only temporary. They will not last.
    Buck rivets preferred, mono bolt rivets will work. Not pops.
    Goodysnap and jason6541 Thank this.
