Can I increase payload of Penske 16ft truck?
Discussion in 'Expediter and Hot Shot Trucking Forum' started by wl90.200, Mar 7, 2023.
  1. wl90.200
    wl90.200 Light Load Member
    52
    7
    Sep 22, 2022
    G3500 2008
    The GVWR is 12,400 LB
    The payload is 4,300 LB
    Moving Truck Sizes and Features - Penske Truck Rental
    Question 1)
    Is there anyway to increase the payload to 6000lb? can I add airbags? upgrade suspension? do something
    Question2)
    Is there a difference between GM 2003 and 2009 truck? I heard the transmission is different. The 09 has 5 speed transmission where the older ones have 4 speed.
    which one is better?
  3. ducnut
    ducnut Road Train Member
    2,587
    7,801
    Dec 31, 2010
    SPI
    1.) You can always add airbags, with auto ride-height control. I have an Air Lift system on my Silverado. It’s awesome. However, you need to look at what the tires are rated for; not the load range, but, the actual pounds. They’re are going to be a weak link. Also, those vans eat rearends, in high mileage applications. I know an expeditor who has put 3 rearends under his, in ~300K miles. My buddy does all the maintenance on that vehicle and it is properly maintained. The engine and trans have had nothing but regular maintenance.
    2.) Both years have the 4L80E transmission, which is the strongest transmission GM offered, short of an Allison behind a Duramax.
    You’ll be subject to many states’ weigh stations. You need to be compliant to your door sticker, if you plan to cross them.
    Mattflat362 Thanks this.
  4. wl90.200
    52
    7
    Sep 22, 2022
    Can I make the gvwr 14000lb?
    so the payload gets increased from 4300 to 6000lb?
  5. wl90.200
    52
    7
    Sep 22, 2022
    what is the max towing for cheavy 3500?
  6. ducnut
    2,587
    7,801
    Dec 31, 2010
    SPI
    No. You can’t change the GVWR. Vehicle’s weight rating is established by the manufacturer, which is what that door jamb sticker is. However, you can do whatever you like, outside of that. Again, if you scaled and you’re over the weight rating, you’ll have to answer for that.
    Air bags will easily increase the carrying ability by that 1700lbs. But, you need to weigh the truck empty and see where you’re currently at. Then, you have to consider the tire load carrying capacity.
    Lite bug Thanks this.
  7. Tumbleweed TowMan
    Tumbleweed TowMan Medium Load Member
    390
    1,714
    Jun 22, 2022
    No, you cant.
    The entire vehicle is based upon ALL parameters of every component it is assembled with.
    Those components have max tolerances, based upon the mfg's determining what gvw that vehicle will be.
    You want to carry more load, get a bigger truck.
  8. Scalemaster
    Scalemaster Heavy Load Member
    808
    1,717
    Mar 13, 2011
    Midwest
    Which is why getting a trailer "derated" is such a sham. No equipment has been changed.
    Vehicle should still have the same GVWR it left the factory with.
  9. Lite bug
    Lite bug Road Train Member
    1,406
    32,034
    May 3, 2014
    Columbus Ohio
    Carrying less weight than the manufacture’s rating has benefits , less wear on the drivetrain, better fuel mileage. What sham ?
    wl90.200 and ducnut Thank this.
  10. wl90.200
    52
    7
    Sep 22, 2022
    I’m talking about g3500 box truck.
    I’ve seen 3 gvwr
    10, 12,300 and 14200
    They all looked the same, same engine, transmission.
    The only difference I see is the leaf springs. Is this right? Or I’m missing something?
  11. ducnut
    2,587
    7,801
    Dec 31, 2010
    SPI
    From knowing someone, secondhand, running one of these in the same capacity you’re planning, I’d caution working that rear axle any harder than necessary. If that dude is an indicator, you’ll be replacing rearends. Revisit my first response.
