Can I run with this?
Discussion in 'Kenworth Forum' started by Lunchman, Sep 28, 2014.
  1. Lunchman
    Lunchman Bobtail Member
    35
    18
    Aug 31, 2014
    So while looking over my truck this afternoon getting rdy for a run in the early AM, I discovered the following: IMG_2725.jpg IMG_2726.jpg IMG_2727.jpg
    This is on the rear axle, I was looking at it last week and it seemed the rubber bushing was working its way out, checking it today it is completely gone. I've got a 650 mile run in the early AM, 1/2 of it is empty, other half will be about 43k on a 40ft container.
    Am I ok to run this, or should I be getting into the shop asap?
  3. nb629
    nb629 Light Load Member
    213
    245
    Aug 21, 2012
    If you have to ask you should get it fixed and you know it. When you saw that it was showing wear you should have scheduled a repair instead of waiting.
    Lunchman and jeepnut_nh Thank this.
  4. Lunchman
    35
    18
    Aug 31, 2014
    How did I know that was coming. Issue is am out in the middle of no where, this run gets me back down to Kansas City. The truck started to feel like it was wondering around a bit on the road, thus me reason for looking things over.
    I'll see what I can do to get this fixed, do I have to replace the entire arm or just the bushing.
  5. CRN
    CRN Bobtail Member
    48
    37
    May 10, 2014
    You already have been running with that but it does need rebushed or replaced
    Lunchman Thanks this.
  6. Allow Me.
    10,665
    12,181
    May 28, 2009
    Rancho Mirage, Ca.
    Yeah the bushing is there for a reason. So without it, the piece can't do it's job correctly.
  7. windsmith
    windsmith Road Train Member
    7,296
    6,031
    Sep 2, 2011
    NEPA
    It probably won't break, but you're going to have some extra axle movement and increased tire wear. Get it replaced ASAP. Any spring shop can press new bushings in and have you back on the road in a couple of hours. I had both of mine done on a '98 Pete, and if I recall correctly it was under $300 for the whole job, and took them about an hour and a half.
    magoo68 and Lunchman Thank this.
  8. Dryver
    Dryver Road Train Member
    2,818
    2,575
    Nov 30, 2008
    Sioux Falls, SD
    Fix things as they need it as it puts strain on other components and it turns into a horrible $$$$$$$$ chain reaction.
  9. mnmover
    mnmover Road Train Member
    1,237
    1,104
    Apr 5, 2009
    Lichfield MN
    get the whole assembly from Freightliner. I replaced mine with sythentic rubber bushings. got them at Freightliner @ Phoenix Cheaper than rubber and longer lasting. It will change the alignment of the rear axle.
  10. Lunchman
    35
    18
    Aug 31, 2014
    Gah - didn't even think about that - so am going to need an alignment as well? Was just reading about the poly bushings the new arms come with.. Good things..
    Also, so everyone can relax, truck goes in tomorrow at 7am to have this fixed. Will have to bobtail about 45 miles or so to get it there, but shouldn't be a problem.
    Just wish to say thanks for everyone's feed back on the forums here!
    MJ1657 Thanks this.
  11. Joed2323
    Joed2323 Bobtail Member
    9
    Sep 30, 2014
    Yes obviously that is bad, but yes you can still run it to the shop to get fixed, if the back one is bad so is the front one i bet
    It wouldnt hurt to pwr wash the fifth wheel and give it a nice coat of grease also:biggrin_25525:
