Can not access 2012 Volvo VNL -in cab - Blower Motor -
I have everything off --and I'm down to the blower motor but can not figure out how
to take the cover off to ACCESS the blower motor -- believe it - its encased with this cover and has
CLIPS that are holding it on - if i remove the CLIPS I could not replace them with out
destroying them --- I looked for a release of some sort but nothing that i can see --
Has anyone taken one of these off ?
I've seen the video online but its not like my 2012 Volvo
Discussion in 'Volvo Forum' started by JerryD13, Aug 26, 2017.
the 2012 volvo comes with an oem blower already in the case so all you need to do is just pull it out swap out the freeze switch and install back if you got oem if not you need to break the case remove the two phillps change blower extend wires then use out side clips to hold blower together
JerryD13 Thanks this. -
Thanks Nasriza - --- I used a knife blade to take out the silver clips ------
but .. after taking the unit out - its not going in as easy - frankly i made a
mess - and I'm not entirely sure that the issue was fixed - it may have not been the
CONTROL UNIT i changed out ..... ??? the motor works - its running.
Blower motor replacement:
