Can somebody explain wheel speed sensors to me
Discussion in 'Ask An Owner Operator' started by MTMAUS, Mar 16, 2025.
  1. MTMAUS
    MTMAUS Light Load Member
    232
    183
    Sep 28, 2019
    hey
    I have a freightliner which keeps coming up with a wheel speed sensor on the 1st axle RH side.
    I got the mechanic to replace sensor and cable, but now it keeps coming up in weird ways.
    I can drive 5000 miles and it won't come up, but then if I drive bobtail it will trigger more often. It will be stuck on for a day, and then the next 5 days nothing.
    How do I measure the ohms to check each sensor?
    where do the sensor cables plug in? do the go to a valve somewhere or go to a computer?
    could the cables be swapped at the valve/computer meaning the wrong location is showing on the dash?
    I am home for a few days soon, so would like to spend some time on it to get it sorted
    thanks
  3. AModelCat
    161,299
    Not sure what sort of faults you're seeing but I wonder if it could be caused by a loose wheel bearing or an issue with the tone ring on the hub?
    Vampire, wore out, KDHCryo and 4 others Thank this.
  4. MTMAUS
    232
    183
    Sep 28, 2019
    sorry forgot to mention I went through a suspension place the other day and got them to check that wheel for movement and they said all was good
    Rideandrepair Thanks this.
  5. MAMservices
    MAMservices Medium Load Member
    548
    3,935
    Aug 9, 2021
    Follow the wire from the wheel end toward the frame and you should locate a connector at the wiring harness. Anything over 2K ohms is considered to be bad.
  6. xsetra
    xsetra Road Train Member
    5,161
    7,092
    Aug 21, 2011
    Also check the wire connections from inside wheel end to computer.
    I have 2 pieces for each cable from wheel end to computer. Those connections can get loose and corrode.
  7. MTMAUS
    232
    183
    Sep 28, 2019
    so the cables go to the computer? I am assuming you could mix up the plugs at the computer so it would show the wrong wheel faulty?
  8. Ridgeline
    22,609
    120,094
    You can’t, sorry it is a sensor that has electronics in it and it is tested by an ac volt meter and spinning the wheel.
    this is a wiring harness problem most of the time, not a sensor issue.
  9. dosgatos
    dosgatos Medium Load Member
    581
    1,267
    Sep 18, 2012
    Start by finding a schematic for the truck wiring. Unplug the sensor and check continuity between the harness plug and the pin out at the abs unit under the dash. Ohm meter, long leads with alligator clips. The twisted pair may have chaffed bare and shorting or the wire may be broken inside the insulation. Copper wire gets brittle with all the vibrations over the years. I have a million mile truck and am chasing broken wires all the time
  10. Rideandrepair
    17,430
    56,538
    Aug 8, 2015
    ECU is usually located on frame cross member, under or at the front of fifth wheel. I would first make sure the new sensor isn’t getting loose and away from the tone ring. Push in on it from the back, using a stick, Long 1/4” extension works good. If good I’d swap the extension wire between sensor and ecu. Unless the new sensor has just 1 long wire straight to ecu. I’d swap the extension wire if equipped. I would also check the ride height. If it’s too high, might be getting wheel spin, especially while BT. Might be aggravated by bad shocks.
    MAMservices Thanks this.
  11. MAMservices
    548
    3,935
    Aug 9, 2021
    With all due respects, why do you say, “you can’t”? What are you suggesting the sensor is designed and made of that cannot be checked with a 10 megaohm multimeter?
