can someone clarify if forklift drivers require CDL?
Discussion in 'Questions From New Drivers' started by thealfa, May 24, 2011.
  1. thealfa
    thealfa Medium Load Member
    407
    15
    Dec 6, 2010
    Does anyone know. I was told it doesn't but just want to make sure. I was told I don't even need a standard driver's license to drive a forklift. I was told the training and test is done by the hiring company so no need for going to a licensing facility like an MVA or certain departments to do forklift driving work. Can someone clarify?
  3. rich_t
    rich_t Road Train Member
    1,448
    73,113
    May 28, 2009
    United States
    You do NOT need a CDL to drive a forklift.
  4. Rerun8963
    Rerun8963 Road Train Member
    3,917
    2,012
    Mar 30, 2006
    ova-hereee
    usually when you get hired on at any company that has forklifts, THEY train you, test you, and certify you..
    i would also like to recommend that if they have any other type of lift equipment, that you ask to be trained on those as well, and be certified..this makes you MORE employable at say a company that has "high lift" trucks....
    and you don't need a CDL license, although again, if you had one, then you could be the "Yard jockey" as well and again, make your self so much more needed with-in the company..never just "settle" for one thing, try to expand your knowledge/skills.
  5. Heirforce1
    Heirforce1 Medium Load Member
    502
    226
    May 16, 2011
    The Windy City
    It's normally forklift and pallet jack certification. ReRun was correct though you definitely don't have to worry about losing your job when you have more than 1 ace for the company. Good luck going forward!
  6. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,538
    Jul 30, 2009
    Mapleton Depot,PA
    forklift certification is a function of OSHA and the individual company, not any state DMV.
  7. sollo5150
    sollo5150 Bobtail Member
    24
    kennewick wa
    No you do not need a Cdl but you might need a certain up to a class eight
  8. Emulsified
    Emulsified Road Train Member
    3,663
    3,499
    May 6, 2010
    Dallas, TX
    FYI, there is a move to come up with a single nationwide Lift truck/motorized pallet jack Safety Certification to be administered locally. right now virtually all locations have their own version of safety training, so long as it meets certain OSHA requirements.
    We've all seen where we arrive at a warehouse and are required to have XYZ certifcation cards in order to use their equipment. And heaven help us if we have ABC version instead.
    I suspect there will be a stanardized certification (license?) within the next couple years. Probably administered by your local DMV or OSHA office.
  9. Allow Me.
    10,642
    12,114
    May 28, 2009
    Rancho Mirage, Ca.
    You do need to be "certified" to operate a forklift, generally by a third party testing place or a fellow employee might be certified to test you. No big deal, real basic stuff. Done in an hour or two. Then you get a little card to carry in your wallet.
  10. lostNfound
    lostNfound Road Train Member
    3,506
    2,269
    Jun 28, 2007
    Home of the Stampede
    You do when you're dragging 53 foot trailers down the Interstate with your forklift.
    x1Heavy and not4hire Thank this.
  11. passingthru69
    Like Rerun posted. You take a class that is OSHA approved.
    There is different class levels for the forklifts. Take all of them if you can.Just because you are certified to a 5 thousand lift does not mean you can run a 30 thousand lift.
    Me I got mine for upto and including a 30 thousand.
    Real easy test and then you do the skills test.
