Can someone help with these codes.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by tnovakow, Oct 25, 2010.
  1. tnovakow
    tnovakow Bobtail Member
    25
    Aug 26, 2009
    allen park mi
    Hi, Got a warn engine light on and reading 2 faults this is what my dash says after i hold the dash button down
    092:s01 128fo1 pid111_a
    some of the 0 might be o's
    I googled and only found one thing about coolant sensor for pid 111
    any one have any ideas. Have a 05 cummins isx egr no dpf.
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    MID 128 - engine
    PID 111 - coolant level switch
    what FMI? May be faulty sensor ore really low level.
    ECM may be programmed to shut engine off with low coolant.
    well, check coolant level and sensor connector and wirnig. If sensor is bad, change with new, don't try to cheat ECM. It may worth engine...
  4. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    This table may help!
    RAG and Everett Thank this.
  5. tnovakow
    25
    Aug 26, 2009
    allen park mi
    THANK YOU pablo-ua, Ok heres the problem. i looked by the resiviour and found a pinhole size leak on the resivour itself right below the add window. I let the engine cool while i went into meijer and bought the high temp epoxy and tried to plug it. I then added about 1 2/3 gallon of coolant and the light went off and no fualts. went on my way and about 10 mins later the light came back on same code. so pull back off to rest area and pinhole is now worse lol and coolant is below the add window again.
    any idea how to patch this pinhole? im kinda jamed up now.
  6. Everett
    Everett Crusty Shorts, What???
    2,095
    6,401
    Oct 20, 2009
    Hampton,Ia
    How big is pinhole, heres what i did once too get home i hit something put pinhole in tank, leaked all way past low, so what i did was i found a wood screw in bottom of my toolbox i had along, then i had some left over jb weld , i mixed that up put on end of screw threads screw that into hole , went into and had lunch for a hour, bout long takes anyway in trkstop, while setting up , went out felt it was hard as a rock,fill it up with antifreeze i had along ,and drove anthor 567 miles not a leak all way back too yard and they opean hood too fix it they couldnt contol there laughing so hard at pointing at it,:biggrin_25523::biggrin_25523:, i just said hey it got home:biggrin_25524: Everett.
  7. tnovakow
    25
    Aug 26, 2009
    allen park mi
    Very small. literally the size of a pinhead. i imagine when it is hot it expands but cant plug while hot becuase of leaking.
  8. tnovakow
    25
    Aug 26, 2009
    allen park mi
    do you think jb weld would be better than the red epoxy? I could try and wrap the whole thing with duct tape. :biggrin_25523:
  9. Everett
    2,095
    6,401
    Oct 20, 2009
    Hampton,Ia
    what kind of truck
  10. tnovakow
    25
    Aug 26, 2009
    allen park mi
    International 9400i
  11. Everett
    2,095
    6,401
    Oct 20, 2009
    Hampton,Ia
    okay find a dealer mayby and if company truck ask them were too take it
