Can someone plz explain to me about sliding tandems
Discussion in 'Questions From New Drivers' started by Dreadheadtrucker, Jun 15, 2017.
Page 1 of 5
you need to be a little more specific with your question.
I mean like sliding them back and forth if my back is over weight (43646) do I move my truck forward ?
How to do it or proper way to move wt?
Dreadheadtrucker Thanks this. -
Yes how to do it
Side the tandems toward the problem. If heavy front slide forward and so on and so forth
TaterFox, IluvCATS, BlackThought and 4 others Thank this. -
There should be a lever you pull.If that seems tight then get back in the truck move forward or backward a bit to loosen up the tension.Didn't your trainer teach you on the tandems?bowhunter67 and CrappieJunkie Thank this.
S
Slide them back if you are 43k on the trailer. That's a lot to move. Hope you don't need a rework -
What are your other axle weights?
Move the tandems towards the weight. I.E. if your overweight on the rear slide them back.
If you really have a weight of 43646 on your trailer axles no amount of movement will ever make that league. That's almost 10,000lb over weight.RustyChops41, shogun, Mr Budeedee and 1 other person Thank this.
Page 1 of 5
