Can someone tell me what this is?
Discussion in 'Ask An Owner Operator' started by Beemer345, Jul 10, 2024.
  1. Beemer345
    Beemer345 Bobtail Member
    12
    5
    Nov 27, 2023
    It’s right above my air tank behind my fuel tank on the drivers side. Cascadia day cab. It looks corroded and detached. I’m just wondering if someone can tell me what I’m looking at. Thank you.
  3. Big Road Skateboard
    6,651
    37,334
    May 2, 2021
  4. wis bang
    wis bang Road Train Member
    3,428
    4,066
    Jan 12, 2011
    Levittown, PA
    and the corroded part is the mounting tab.
    Beemer345 Thanks this.
  5. 2Tap
    2Tap Medium Load Member
    458
    931
    Jul 19, 2022
    Southern Wisconsin
    I highly doubt it's a solid state circuit breaker.
    It appears to be a ground and that block looks like a filter to keep "noise" off the ground.
    Whatever you do re terminate that sucker and keep dielectric grease on it. It doesn't matter what it is as much as it's corroded and disconnected and shouldn't be.
  6. Ridgeline
    22,609
    120,101
    It is something that you need to go to the dealer to get fixed.
    Numb and motocross25 Thank this.
  7. Iamoverit
    Iamoverit Road Train Member
    2,159
    4,941
    Oct 31, 2023
    Looks like a low voltage disconnect but if it is it must have been removed on the other end at the battery bank. Because if it was still in the circuit your truck wouldn't start in that condition at all.
  8. DixonM
    DixonM Medium Load Member
    372
    782
    May 22, 2022
    It’s a circuit breaker
    86scotty Thanks this.
  9. Lazer
    Lazer Road Train Member
    1,826
    2,931
    Jan 22, 2017
    Looks like one of those ‘power cut-off’ switches that you flip off at the end of the day. Most likely the switch is on top, knob missing. Popular years ago, way before today’s electronics gizmo’s that require 24hr juice.
  10. 86scotty
    86scotty Road Train Member
    4,632
    12,605
    Aug 27, 2017
    Appalachia
    Yep, reading this post is fun though. What I can't figure out is whether it's a vanilla or a chocolate one.
    OP needs to start the truck up and lick both posts as well as the end of that loose wire and tell us if it's vanilla or chocolate.
    Siinman Thanks this.
  11. Beemer345
    12
    5
    Nov 27, 2023
    Battery is completely healthy and fully charged. No issues with starting. Was just curious about it. Thanks everyone.
