Can Volvo EGR be turned off/bypassed?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by CMTrucking, Dec 31, 2009.
  1. CMTrucking
    CMTrucking Light Load Member
    85
    27
    Dec 25, 2009
    Kamloops, BC
    I've seen how the EGR can be shut off on the ISX's, is there any easy way to do this with the Volvo D-16's?
  3. lowbudget
    lowbudget Medium Load Member
    428
    110
    Apr 12, 2008
    Bismarck, ND
    doesn't the D-16 have a DPF? If you shut off the EGR in a DPF equipped engine, you wil clog up the DPF in a day.
  4. CMTrucking
    85
    27
    Dec 25, 2009
    Kamloops, BC
    Pre-07 engines didn't have DPF.
  5. lowbudget
    428
    110
    Apr 12, 2008
    Bismarck, ND
    You didn't say yours was pre-07. Try unplugging it when the engine is cool and the valve is closed?
  6. CMTrucking
    85
    27
    Dec 25, 2009
    Kamloops, BC
    Sorry, should have specified. I don't have one, but am considering buying one. Just looking to see if there are easy ways to derestrict them for better fuel economy.
  7. CMTrucking
    85
    27
    Dec 25, 2009
    Kamloops, BC
    Any Volvo techs? Is it as simple as a blocking plate, or will this cause problems with the computer?
  8. hey11101
    hey11101 Bobtail Member
    11
    Darien,IL
    I have 2005 volvo with d12 engine and the EGR's have been welded shut. I also heard that it is not possible for volvo engines to get EGR's shut off like on ISX's. My fuel economy has went down to 5.6mpg and the truck driver said it does not pull like it used to. I am currently thinking of getting the welds off but I am not sure if t can be turned off by a computer also. The check engine light is on also which I am not sure if it;s because of the EGR being blocked off.
  9. hey11101
    11
    Darien,IL
    Someone must have more info on this issue.
