Can you beat it? DD15 1,165000 MILES
Discussion in 'Ask An Owner Operator' started by Trenton325, Jun 25, 2022.
  1. Trenton325
    Trenton325 Light Load Member
    102
    154
    Feb 7, 2019
    Just Curious. I have over a million miles on my 2014 DD15 I put 800000 on it myself still never been overhauled. I don't burn oil at all. Change oil every 45000 miles with full synthetic and still have the DPF intact with the original one box.
    Now that's not saying I haven't had a lot of repairs like everyone else I quite literally have replaced 70% of everything attached to the engine myself which has prevented down time. But the engine it self has been a beast
    Just curious what other DD15 people have experienced?
  3. JoeyJunk
    JoeyJunk Road Train Member
    8,763
    68,032
    Dec 31, 2010
    Washington, PA
    That’s pretty good. Having the original one box is nothing short of a miracle. I assume you have replaced all the guts of that one box?
  4. Trenton325
    102
    154
    Feb 7, 2019
    Thank s
    I haven't replaced them but I've cleaned them myself 3 times with high pressure hose. I talked to some mechanic friend of mine that work primarily on freightliner they said that box gets replaced way to often by mechanics that don't want to properly diagnose them. They said they've only had to replace the one box if there was damage from outside force I don't know.
    But on the outside of the box I've had to change everything wiring harness nox sensors temperature sensors ect. But hopefully the DOC AND SCR keep holding up. But if they don't guess Iran money a head any way. Lol
  5. armo
    armo Light Load Member
    274
    290
    Jun 16, 2022
    @Trenton325 did you replace main and rod bearings ?
  6. Trenton325
    102
    154
    Feb 7, 2019
    No the oil pump cause I was told the Seals go bad but I never saw oil pressure problem I figured it was a good idea.
  7. armo
    274
    290
    Jun 16, 2022
    where do you drive? southern area where is hot climate or north?
  8. Trenton325
    102
    154
    Feb 7, 2019
    Most in Texas about 3500 miles a week usually weigh around 75,000 plus.
    The first 200,000 miles I put on it was regional through the rocky mountains.
  9. Trenton325
    102
    154
    Feb 7, 2019
    Thank you
  10. D.Tibbitt
    150,996
    everybody thinks emissions motors dont last .. hoping to get as much work out of my cummins
