I've got this stubborn coolant leak that I've been fixing and dealing with for about 3 years. **picture attached, blue hose**
I'll fix it and it'll be fine for months maybe a year then slowly it'll start back seeping and weeping just a bit. I just put this new hose on and three days later it's seeping a bit. -it's a bad design to me, the spot where the hose attaches to the T fitting is THREADED: so I'm clamping a hose onto threads.
Because of this I think it never really gets the seal it needs.
OK NOW TO THE QUESTION:
Can I do away with the T and just simply build a union connection to go straight through, Ditch the T fitting completely? Since I've owned this truck I've never really used the bunk heat or air. I have a tri PAC and a bunk heater
Can you bypass the sleeper heater core?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by HopeOverMope, Apr 26, 2017.
Page 1 of 3
No reason you can't do away with it or get the correct hose nipple & put it on.
starmac, AModelCat, Rideandrepair and 3 others Thank this. -
Yes, you just need a hose barb, you can't just clamp onto threads. Get a bard that threads into the existing threads.
HopeOverMope Thanks this. -
The clamp on the black hose is too large for the hose and the nipple, or the nipple is too small. If you have to tighten the clamps so much to get a seal that they are damaging the hose, then something is not right.
Rideandrepair and HopeOverMope Thank this. -
I called my fitting store, could you tell by looking it: what type of thread that may be? I know it's not JIC
It looks to be aftermarket when the apu was installedRideandrepair Thanks this. -
Makes since. I need to get some hose barbs like uncleal13 said
Then it would actually have a good surface to mate with -
They look like standard pipe thread from the picture.
Rideandrepair, mslashbar and HopeOverMope Thank this. -
Thanks, I'd rather try and keep it because I know it kind of acts as a second radiatior or sorts to help keep the water cool.
I know it's probably a "duh" moment, just didn't want to bypass it and mess up that core back there etcRideandrepair Thanks this. -
Thanks
The answer to "Can I bypass the sleeper heater core?" is yes, if you have the shutoff valves on the engine. Most do.
Trace your lines from the sleeper to the front and rear of the engine block and shut those two valves off.D.Tibbitt Thanks this.
Page 1 of 3
