Can you drag a truck with Autoshift transmission in neutral around the yard?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by ichudov, Mar 8, 2018.
  1. ichudov
    ichudov Heavy Load Member
    742
    642
    Mar 14, 2012
    Berkeley, IL
    I have a truck with leaked out antifreeze on my RGN trailer. I need to get it off the trailer and move it about 200 feet. I do not really want to start it, I would rather air up its air system and drag it with a forklift, with the transmission in neutral.
    It has a three pedal Autoshift transmission.
    I read warnings about disconnecting a driveshaft, but I am not sure what I would harm if I would slowly drag it with a forklift for a short distance.
    Any idea
  3. Slowpoke KW
    Slowpoke KW Road Train Member
    1,170
    12,826
    Dec 7, 2015
    OK
    For that short of a distance it won't hurt anything
    I've personally pushed and pulled them around a yard like that several times back when I turned wrenches for a fleet that had nothing but autoshifts both two and three peddle
    I had a wrecker driver tell me one time that they won't pull a drive line if they are going less than ten miles
    ichudov Thanks this.
  4. uncleal13
    uncleal13 Road Train Member
    3,797
    6,296
    Apr 9, 2009
    Humboldt, Sk
    Probably fine. I know for sure you cannot do it with a Volvo iShift, any distance at all and it is trashed.
  5. ichudov
    742
    642
    Mar 14, 2012
    Berkeley, IL
    can you roll down a hill with the iShift in neutral?
  6. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,139
    Mar 5, 2016
    White County, Arkansas
    We have dragged trucks and loaded trailers with spring parking brakes engaged during winter storms a few times. Latch a bobtail onto it three chains run three times through tackle and then hammer the low gear out of it.
    Drag that deadweight with no wheels rotating at all around to the back of the shop. 80000 pounds of it.
    My poor tractor... poor bairns...
    It took the abuse and ran fine. But it's a manual and not a auto.
    I tell you this. If your auto is in nuetral it should not know much about being towed. You do not want to tow it very far without taking the drive axle out of it.
  7. Jazz1
    Jazz1 Road Train Member
    2,373
    4,971
    May 7, 2012
    Thunder Bay On
    I had engine in 2014 Cascadia quit running descending a grade so decided to see how the POS reacted. I shifted to neutral, turned ignition off then back to ON position and shifted to drive and engine restarted. Carried on, don't know if its ok to do but I recall 1940's automatic transmissions could be push started give it a whirl
    uncleal13 Thanks this.
  8. Dave_in_AZ
    411,693
    I'm way lost. If it's in neutral what difference does it make?
    And if you go to the trouble of dropping the drive shaft, I sure don't see how that could harm anything.
  9. Steel Dragon
    Steel Dragon Road Train Member
    2,681
    2,833
    Nov 23, 2015
    No!
    They remove the driveshaft when towing.
    I guess you could remove the drive shaft disconnecting the transmission from the wheels.
  10. Steel Dragon
    2,681
    2,833
    Nov 23, 2015
    Lets experiment with a $10,000 transmission!
    :withstupid::violent1::tool::toothy1:
    Roger McG and tucker Thank this.
  11. QuietStorm
    QuietStorm Heavy Load Member
    899
    1,416
    Dec 11, 2016
    Happened twice to me in the same truck. I'll never drive an auto again.
    Dave_in_AZ Thanks this.
