Can you get qualcomm with elog service being an oo?
Discussion in 'Ask An Owner Operator' started by NewNashGuy, May 11, 2013.
  1. NewNashGuy
    NewNashGuy Road Train Member
    1,616
    752
    Jul 27, 2011
    US and Canada
    I was wondering if you could have the qualcomm e-log service as an independent owner operator? If so what is the cost roughly? I mainly would want e logs so that DOT will not harass me. Every time they see I have e logs they don't even bother checking.
  3. MNdriver
    MNdriver Road Train Member
    7,985
    4,372
    Feb 24, 2012
    when I looked into it last summer, They were telling me $1800ish to install and $40.50 for monthly fees.
    And it's not even going to be compliant with federal requirements.
    I have since found out, installing this into the wiring on the truck screws things up more than anything. Causing drivability issues.
  4. Ranger Bob
    Ranger Bob Light Load Member
    245
    210
    Jan 20, 2013
    Yes you can but why would you.....just use Driver's Daily Log. When the DOT asks for your logs you simply tell them hang on I will print them out.....most often when they see you are using computer logs they say never mind and move on to the next issue unless you give them a reason to think differently. Be aware you are still required to be able to provide copies of your current day in service as well as signed copies of your previous 7 days if asked. I don't use it but know many who do and I believe the cost is less than $125 to get started......I don't know if there is an annual charge or a charge for upgrades but it is certainly more affordable than a qualcomm unit and nothing is tied into your ECM.
  5. Roadmedic
    Roadmedic Road Train Member
    18,951
    8,981
    Apr 4, 2007
    Not qualified as eobr or electronic logs.
  6. Roadmedic
    18,951
    8,981
    Apr 4, 2007
    I am concerned about this possible mandate and hooking something up to the truck that may cause operational difficulties with the engine. I am sure there have been some problems and it would not be good in my opinion.
    cetanediesel Thanks this.
  7. Cranky Yankee
    Cranky Yankee Cranky old ######
    15,317
    209
    Jan 31, 2012
    Green Bay Wi
    isnt there a rand mcnally out now a 760
    that is an elog also for $700
  8. MNdriver
    7,985
    4,372
    Feb 24, 2012
    when I was looking for my issues with my dash gages not working, I went to Freightliner to have them clear the codes.
    Their software would NOT recognize the truck. We'd have to enter the serial number manually. Then it would give us a "no qualcomm found" error message.
    Once we took ALL of the qualcomm wiring out of the vehicle, plugged it into the computer, no more ID issues. Hook up the computer, turn on the key, they would communicate immediately.
    the "connector" that splices into the 9-pin connector for this seems to be the biggest thing that gives it fits. Often times breaking wires and causing issues.
    It's not as benign as they'd like you to believe it is.
    25(2)+2 Thanks this.
  9. Roadmedic
    18,951
    8,981
    Apr 4, 2007
    What will you do when they are mandated?
  10. fortycalglock
    fortycalglock Road Train Member
    6,155
    6,584
    Jun 25, 2011
    Tourist Town, FL
    TA sells a Rand McNally EOBR for $650ish plus monthly fee.
  11. Roadmedic
    18,951
    8,981
    Apr 4, 2007
