Can you haul Crude Oil on a Vacuum Trailer?
Discussion in 'Oilfield Trucking Forum' started by daf, Dec 13, 2012.
  1. daf
    daf Light Load Member
    199
    42
    Dec 19, 2011
    Ks
    Can water haulers load crude oil or chemicals on water vacuum trailers legally?
    What if it's in small amounts like 5 BBLs mixed with production water?
  3. Big Duker
    Big Duker "Don Cheto"
    2,921
    2,867
    Sep 18, 2007
    Weatherford, TX
    Most chemicals are hauled in plastic cages and mixed in tankers similar to but different than water. Most have couple of hatches together in middle. TriCans are lined with something. Marked for HazMat etc. At least of frac jobs. Not sure how much oil is in waste water. I think it is picked up separately but could be wrong. And oil tankers are totally different.
  4. JoeyJunk
    JoeyJunk Road Train Member
    8,763
    68,030
    Dec 31, 2010
    Washington, PA
    Sure they can, just mark the truck BRINE WATER. :biggrin_2559:
  5. JoeyJunk
    8,763
    68,030
    Dec 31, 2010
    Washington, PA
    Good question. There is no way of knowing the amounts of the chemicals in produced water, without actually testing it, which doesent happen. Everything up here is either fresh water or brine water. There is a guy here from PA that hauls or used to haul water to frac sites. Hopefully he sees this and chimes in.
  6. eddy87
    eddy87 Bobtail Member
    14
    7
    Dec 2, 2012
    my dad and brother both drive vac trucks and there is always oil mixed in with the water there permits allow them to haul most any thing they can suck up into the trailer and where i live the companies that have vac trucks make all the drivers have hazmat so they can haul chemicals and such they have even went and loaded crude oil when the crude trucks were tied up somewhere else so i would say if they have the right permits they could haul it
  7. daf
    199
    42
    Dec 19, 2011
    Ks
    wouldn't the crude oil fumes blow out by the front of the vac truck? Couldn't that cause a fire? How about chemicals blowing out by the cab of the truck when you are pulling a load?
  8. eddy87
    14
    7
    Dec 2, 2012
    I am not sure about that I think they have some kind of vapor recovery system on it or they pull from the bottom of the tanks so gravity does some of the work and they pull a vaccum on the trailer and turn the pump off but I know they havent blown anything up yet but I will ask
  9. Guntoter
    Guntoter Road Train Member
    1,659
    1,521
    Mar 24, 2012
    Phoenix, AZ
    **Smacks forehead**....
    If you're a professional with a Haz-Mat CDL, Haz-Mat carrier authority, and a 5 million dollar PLPD insurance policy you probably already know about 49CFR 172.101 that tells you as long as the HM doesnt exceed 10% of the overall bulk liquid then no placards are required.
    If you dont have all those things I mentioned then you probably dont want to get caught with 11% oil in that water 'cause thats a hefty ticket, CSA, and if you hurt someone its criminal negligence.
    RockinChair Thanks this.
  10. eddy87
    14
    7
    Dec 2, 2012
    ok I asked my dad about this and the trucks have this thing called a VOC scubber that cleans the air coming out of the tank and returns the vapors back into the tank and the clean air back to the atmosphere if that makes any sense there trucks have placards and all the insurance and stuff to carry it leagally
  11. Guntoter
    1,659
    1,521
    Mar 24, 2012
    Phoenix, AZ
    Yeah, any HM transporter knows the RQ amounts.
