Can you put a mechanical pump on a 3406BPEEC engine?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by durtmvr, Feb 22, 2014.
  1. durtmvr
    durtmvr Bobtail Member
    18
    Feb 22, 2014
    Need a 3406b engine for an old truck. Found a PEEC engine out of a T600. Can I put my injection pump on this PEEC engine? Can I put a 3406E in it and use the harness off of the T600 if I buy the whole T600 for parts?
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    things are not so easy.
    3406E and C15 are with pump injectiion units, cylinder head and cam shaft are totally different.
    it is much easier to fit 3406E with ECM, wiring, TPS and switches in your truck
  4. kwforage
    kwforage Road Train Member
    1,047
    472
    Jun 3, 2007
    Wisconsin
    I have a 94' 379 with a 3406B PEEC that was converted to a mechanical pump. It's a 4CK motor. It runs strong. Bought the truck that way so I have no idea what they did to do it but I'm glad they did!
  5. durtmvr
    18
    Feb 22, 2014
    I have a truck with a 3406B. I'm looking at a donor truck with a 3406BPEEC engine. Will the B pump fit the BPEEC engine without changing a bunch of stuff?
  6. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    yes. u can, but EDC fuel pump is more accurate and fuel milage is a bit better
  7. durtmvr
    18
    Feb 22, 2014
    What will I have to change? Will I have to get the harness rewired on the other truck? Does the PEEC have an "electronic" fuel pedal? The donor truck is an early 90s T-600. The engine needs to go into a 90s 378 Pete that has a mechanical linkage. What other if any malfunctions will I encounter in the swapover if I do not change the PEEC pump over with my mechanical pump?
  8. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    really I'd prefere Electronic Diesel Control.... so check for all electronic components. if something is lost it woiuld be a problem, becouse this engine is not supported
  9. little cat 500
    2,048
    1,092
    Jan 17, 2010
    Abbottstown PA
    i think you can just put the b back have on the peec pump never did it but have here that and you would need the pedal from the other truck
  10. wore out
    wore out Numbered Classic
    15,632
    188,859
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    The peec will have an electronic pedal if you are putting the peec into a manual truck using the manual fuel pump there should be no problem. The PEEC's have a bad reputation but don't really deserve it. Its more fault of the guy working on them than the technology. Electronic engines were not accepted yet at the time. I have converted a bunch due to customer request its not a big deal really.
  11. Exiled
    Exiled Light Load Member
    181
    29
    Apr 20, 2013
    On different truck , Renault to be exact, i was told by a mech. That when u install the mech. pump, that u just disconnect the wire that comes from the pump to the ECU
