Can I add SAE 5W40 to the steering fluid reservoir on the International 9400i?
What about SAE30 or SAE 15W40?
Those are all motor oil.
Thanks
Can you put SAE 5W40 to steering reservoir
Discussion in 'Questions From New Drivers' started by Albert Wesker, Oct 4, 2011.
Page 1 of 3
I have done it in several trucks over the years. Used Rotella 15w40. Also use it in ford pick up power steering.
normally I would use 15W40 but I ran out, so I added some 5W40, I wonder if that damages anything?
this question is not stupid because I'm not sure if I can add specific type of motor oil in the steering
Anyone else? -
TowHaul, Fatback and Albert Wesker Thank this.
being a trained and certified mechanic ill say you can run just about any oil in a steering system as long as it multi viscosity, unless specifically stated on the cap or resevoir, but usually your ok.
otherhalftw and Albert Wesker Thank this. -
I always run ATF in my power steering.
I suggest staying with beer or wine.....that hard liquor can really do you in!Albert Wesker Thanks this.
Page 1 of 3
