Can you run on the passenger side tank only?
Discussion in 'Ask An Owner Operator' started by Okie Trucker Girl, Jan 19, 2022.
  1. Okie Trucker Girl
    Okie Trucker Girl Bobtail Member
    30
    63
    Jan 3, 2022
    Need your help again guys. Got a dent in my drivers side fuel tank, near the bottom of course, and it caused a really bad leak. I tried JB weld but it’s too cold so it didn’t harden over night even though it did stop the leak while I was sitting. Once I started driving on the highway the leak came back. Is there a way to only run on the passenger side tank until I can get the driver side fixed/replaced? Volvo VNL 2012
  3. buddyd157
    buddyd157 Road Train Member
    13,582
    34,896
    May 25, 2017
    under a shade tree
    i imagine so. i had to get up under the chassis and turn ON the fuel tank, when the shop had for whatever reason, turned it OFF....lol
    get up underneath, and look for shut off valves?
    but you will still have that leak you must take care of too!
    you might have to find a stick, tree twig/branch, maybe some rag, stuff it in there and patch it up?
    one company i had worked for, supplied us with different sized wooden dowels for such an emergency repair
  4. SmallPackage
    5,702
    18,226
    Dec 20, 2019
    Marion Texas
    The problem you are still going to have is the fuel return may still go into the tank that has been shutoff. It will still fill if it does.
    Badmon, Dino soar and tscottme Thank this.
  5. Cattleman84
    Cattleman84 Road Train Member
    9,999
    71,348
    Nov 1, 2017
    The Sticks, Idaho
    What kind and year of truck... Many newer trucks draw fuel only from the drivers side tank. Most older trucks I've had experience with draw off both tanks.
    WildTiger1990 Thanks this.
  6. skallagrime
    skallagrime Road Train Member
    3,853
    9,925
    Apr 10, 2012
    Indiana
    Lowes etc, youre looking for "flare" fitting in brass, get 2 plugs and 2 caps in 5/8" and 1/2".
    Remove lines into driver tank, cap and plug.
    Its fine, just a pita when fueling. and make note if only driver side tank has your fuel gauge.
    If you cant pump to passenger side, plug return line to drivers side, then idle truck to drain driver side.
  7. Okie Trucker Girl
    30
    63
    Jan 3, 2022
  8. Okie Trucker Girl
    30
    63
    Jan 3, 2022
    Okay, now I’m really confused. When I stopped, the patch did hold, but my fuel gage dropped 1/8 tank after just under two hours of driving and I’m empty. Maybe I’m just being paranoid, but I thought that was a lot?
  9. skallagrime
    3,853
    9,925
    Apr 10, 2012
    Indiana
    Slosh during transit?
  10. Ridgeline
    22,636
    120,662
    Get it fixed right asap, if the leak is detected by a cop, or discovered the patch to be wet, they can put you oos for it.
    Badmon, wis bang and Okie Trucker Girl Thank this.
