Can you seal the ac lines for the sleeper on a Volvo?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by visoiuvlad, May 22, 2017.
  1. visoiuvlad
    visoiuvlad Light Load Member
    121
    63
    Sep 5, 2014
    the lines are 550$ and the work is 300$ so I was thinking on just seal the lines and just have ac on the front.
    Any ideeas?
  3. Ridgeline
    22,216
    114,143
    Sure you can cap off the lines but I wouldn't try it yourself, take it to the dealer and pay to have it done.
  4. visoiuvlad
    121
    63
    Sep 5, 2014
    how about a temporary fix to just buy a portable ac? and when I will have the lines just use the portable one at my house? any problems with this setup?
  5. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    if its the fittings that are leaking you may be able to replace the o rings, if its the line itself best to replace them. on my old fld blew out a sleeper line in hot weather on a tight budget ended up cutting off the lines and soldering caps on them, and only had front ac with the little 42 inch flat top i found i stayed plenty cool like that and never did end up replacing the lines to the sleeper, a big volvo cab though doubt your going to get enough cold air from just the front.
    visoiuvlad, snowman_w900 and wore out Thank this.
  6. KB3MMX
    KB3MMX Road Train Member
    3,069
    2,589
    Dec 29, 2014
    Orrstown, PA
    This might sound mean but honestly if you can't afford doing that small repair Correctly and need to rig up junk you should evaluate your business maybe. Fixing a $800 issue the RIGHT way shouldn't be a problem.
    Sorry man
    visoiuvlad and boneebone Thank this.
  7. Luwi67
    Luwi67 Heavy Load Member
    746
    484
    Oct 24, 2012
    Long island
    Wrecking yard for the lines maybe.
    visoiuvlad Thanks this.
  8. little cat 500
    2,046
    1,090
    Jan 17, 2010
    Abbottstown PA
    if it has a rubber line toward the back run a bolt in there tight and put a hose clamp around I did mine like that 4 years ago an still in business I see no need for it back there my dash keeps the whole truck nice an cool
  9. visoiuvlad
    121
    63
    Sep 5, 2014
    It's like I really like to fix things and it gives me joy if I can fix it by myself. This part I've solved quickly with some 5$ aluminium pipes and some pressure fittings so lets say the saving money part was a plus. But doing the job with some basic tools and some cheap parts really made my day. Even if it aind going to last because of vibrations still was fun to try. I have 2 weeks now and everything it's working perfect.
    KB3MMX Thanks this.
  10. visoiuvlad
    121
    63
    Sep 5, 2014
    I also did a diy)))) and it's pretty neat)))))
    baha Thanks this.
  11. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    You can use a auto A/C repair shop that only works on only a/c most can use a small torch to weld any breaks in alloy lines and refit all rubber lines with damage for a tenth of what a dealer will charge to replace your lines?
    KB3MMX Thanks this.
