Can you spot the double brokered load?
Discussion in 'Freight Broker Forum' started by windsmith, Jan 30, 2013.
  1. windsmith
    windsmith Road Train Member
    7,296
    6,032
    Sep 2, 2011
    NEPA
    Posted on ITS:
    Tobyhanna, PA to Redstone Arsenal, AL, hazmat, 22000 lbs.
    Broker: Black Water Enterprises Rate: $2800
    Broker: High Plains Logistics Consulting Rate: $1500
    Unbelievable.
  3. aiwiron
    aiwiron Road Train Member
    5,927
    5,228
    Aug 24, 2011
    Sunny Tampa Florida
    Even at 2800 that is scab rates for hazmat
    rollin coal Thanks this.
  4. windsmith
    7,296
    6,032
    Sep 2, 2011
    NEPA
    I'm thinking that it's explosives, given the shipper and receiver.
  5. aiwiron
    5,927
    5,228
    Aug 24, 2011
    Sunny Tampa Florida
    No explosives, most likely waste petroleum. Redstone has a incinerator and used to haul to them, most likely drums of recovered soil that was contaminated by spills or accidents. It takes all day to get loaded and unloaded, figure 48 hours of government B.S.
    We hauled by the load and payed well, just never less than 5.00 per mile but in today's market some under achiever will take it.
    windsmith Thanks this.
  6. MNdriver
    MNdriver Road Train Member
    7,985
    4,372
    Feb 24, 2012
    Likely both are actually triple brokered.
  7. BigBadBill
    BigBadBill Bullishly Optimistic
    4,599
    4,439
    Oct 2, 2010
    Chattanooga, TN
    Make sure you understand the difference between co-broker and double broker. If you can get into a good relationship with a broker that is working with a large 3PL that will only work with carriers of a certain size you can do very well.
    And this comment has nothing to do with OP.
  8. cominghomesc
    cominghomesc Light Load Member
    276
    117
    Apr 20, 2010
    sc
    This is correct and happens quite often. I will often lay off excess loads to other brokers that I cannot get covered with my own brokerage/trucks example being that a customer called in 15 extra loads they needed picked up between monday and tuesday of last week. So I called a local CH Robinson branch who I have done this before with and they moved 8 of the loads. You have a contract similar to what a carrier would fill out.
  9. rollin coal
    rollin coal Road Train Member
    13,474
    27,502
    Mar 29, 2008
    TN
    Redstone Arsenal is more of a R&D military base.. ..not so much bullets/ammo and troops.
    aiwiron Thanks this.
  10. fortycalglock
    fortycalglock Road Train Member
    6,160
    6,601
    Jun 25, 2011
    Tourist Town, FL
    You'll never haul or see loads posted for military bullets or explosives. The loads are not brokerable and can only be run by teams with gov clearances and satellite tracking. This small sector is called AA&E. Landstar Ranger is an AA&E carrier and the loads are never posted to the internal load board, only by Qualcomm.
    windsmith and aiwiron Thank this.
  11. cominghomesc
    276
    117
    Apr 20, 2010
    sc
    I am guessing they pay pretty well
