Can you still have a microwave and watch TV without an APU? OR do you have to idle all the time for
Discussion in 'Questions From New Drivers' started by ThisisMeUsee, Jun 21, 2018.
  1. ThisisMeUsee
    ThisisMeUsee Light Load Member
    57
    22
    Mar 12, 2018
    No APU's in my truck. Can I still microwave food, watch tv or play on video game consoles?
    TravR1 Thanks this.
  3. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    Depends on your inverter and the number and quality of your batteries. Things that pull more juice might make the inverter alarm go off. Idling the truck may or may not help stop the alarm. With some things, it's the initial startup that pulls the most wattage.
    If you have 4 good batteries, you can run quite a bit of appliances with engine off before your inverter starts complaining about low supply voltage.
  4. FwL
    FwL Medium Load Member
    438
    331
    Aug 30, 2011
    Sandpoint, ID
    I have to idle to run a 1700 watt microwave. I run an igloo cooler 24/7, surf internet on my laptop, charge phone, etc without idling.
    If I run the bunk heater, I'll usually get a rude awakening in the wee hours from the low battery alarm going off.
    Lepton1 and RedRover Thank this.
  5. Odin's Rabid Dog
    Odin's Rabid Dog Heavy Load Member
    704
    1,717
    May 6, 2018
    NW MT
    Appliances all have tags somewhere on them listing specs, look for watts.
    There's a huge difference between a microwave and a PS4. I think a PS only draws like 100 watts, roughly. That'll be like 1/8th to 1/12th of what a nuke will draw.
  6. Moose1958
    Moose1958 Road Train Member
    15,104
    33,199
    Dec 17, 2010
    Williesburg, Virignia
    PLEASE PLEASE if you are considering installing an inverter have it installed by a company shop. For every 100 watts you use there is a bit over 8 amps being drew out of those batteries. You should also be at least idle the engine while using an inverter like this. Most class 8 trucks have a battery protection system that will kick in and cut off the power system once the storage in the battery gets below a point. Most inverters are connected directly to the battery and this gets bypassed. Use your head install the inverter correctly and idle. You should be OK.
    Lepton1 and Odin's Rabid Dog Thank this.
  7. TravR1
    TravR1 Road Train Member
    3,693
    9,557
    Nov 9, 2017
    TX
    Why don't you just game on a laptop? When the truck is idling, it will charge your battery; when it shuts off the battery will keep your game running til the truck starts again.
    The Acer Predetor Helios 500 is supposed to be made available in the states within a few weeks. Its an i9 processor with latest and greatest graphics card and its a solid state drive, so you won't have to worry about the bumpy ride ruining the spindle in your traditional disk drives.
  8. TravR1
    3,693
    9,557
    Nov 9, 2017
    TX
    I have teamed with two guys that game on consoles in the trucks we use without APUs. They always seemed to have problems with their games cutting off when the truck does. I'm no expert on how it all works with trucks. But I have the luxury of being a computer gamer. I dont touch consoles. Like having a computer for other things like running my stock market software. Now that I am making decent money and always on the road, that's more important than ever.
    Anyway, that's my pitch for switching over to pc gaming... Gaming the right way. :blackknight:
  9. tscottme
    tscottme Road Train Member
    When your truck burns to the axles because of a driver-installed inverter installed with long tiny cables make sure to sift through the ashes to remove the inverter before the fire trucks arrive.
    Lepton1, RedRover and nax Thank this.
  10. JLMooreKCMO
    JLMooreKCMO Light Load Member
    282
    295
    Jun 8, 2007
    I told somsome this early this spring , they called me a liar.
  11. Wooly Rhino
    Wooly Rhino Road Train Member
    3,367
    5,647
    Jul 6, 2008
    Liberty, Missouri
    If your company does not provide an APU and an Inverter for you, you are working for the wrong company.
    With all the no idle states APU's are needed for driver comfort and safety.
    tscottme and Odin's Rabid Dog Thank this.
